Hi all. I'm looking to build nice loudspeakers
. I was thinking of building the "Pluto" from Linkwitz (not very expensive, and supposedly one of the best loudspeakers out there).But looking over there, there's a lot of nice reviews about quality fullrange drivers like alpair10, jordans, etc., especially about the good sound dispersion off-axis and how this make the soundstage quite real (one of the best features of the linkwitz loudspeakers) My question is: has someone listened fullranges like the alpair10, jx92s jordans, and compared to the Pluto(or even a nice open baffle system)? Because the cost of building a pencil series for the alpair is cheaper than the pluto, and if the alpair it's not so different to pluto, then .. .
#2 |
Well, there's two separate points there -inherent dispersion characteristics in drivers, & the polar response of different types of cabinet.
1st one 1st. The Alpairs have excellent dispersion compared to most wideband drive units. They won't match a 1in tweeter, but they're very good for what they are. Re cabinets, Pluto is a (semi) omnidirectional design; something like a Pencil is a monopole. The former will by definition have a wider (albeit more diffuse) dispersion character with a higher ratio of reflected to direct radiation. This is frequency independent / constant directional however, at least through the region they are functioning in this way. Last edited by Scottmoose; 19th February 2011 at 09:57 AM. |
#3 |
yeah, i know they aren't the same thing, but if a pencil alpair is comparable in sound quality to the Pluto, its a nice alternative
#4 |
frugal-phile(tm)
I've not heard pluto, but i have played with drivres in the same family. The separate mid-woofer might give it an advantage in ultimate bass, but Alpair 7 or 10 should flatten it everywhere else. Even CHR70 or EL70 would give Pluto a run (regardless of the money)
Mark is really setting new standards of performance with his drivers. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 | |
as alpairs are a different design than other fullranges, maybe they are an exception and comparable to the best dynamic speakers |
#6 |
They should be in qualitative terms but remember that as they are very different types of design, this will be reflected in their sound. I did not design the Pensils to be an omni-directional speaker.
#7 |
#8 |
frugal-phile(tm)
Pensils are Scott's -- i only did the drawings... all the relevant information is in the title block.
dave
#9 | |
#10 | |
BTW: Scottmoose was the designer of the pensil. If you keep track of his doings, you'll soon find that he has a "history!" ![]() Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
| FS: Major Caps Upgrade for Linkwitz Pluto Loudspeakers | cuibono | Swap Meet | 6 | 7th May 2011 12:48 AM |
| Pluto with Alpair 12 | ackcheng | Markaudio | 13 | 3rd May 2010 12:47 PM |
| Jordan JX92S from EAD or Mark Audio Alpair 10? | ilwooz | Full Range | 56 | 20th March 2010 01:26 AM |
| FS:Linkwitz Pluto | Nikola Krivorov | Swap Meet | 0 | 2nd October 2009 08:44 AM |
| Alpair 10 wide bass driver and Alpair 10 Fullrange | _henry_ | Full Range | 71 | 15th March 2009 11:37 AM |
| Page generated in 0.11129 seconds (82.01% PHP - 17.99% MySQL) with 11 queries |
