I have an old, broken but beautiful 50's radio that I'm replacing the electronics in. Unfortunately the speaker paper cone has a hole in it, and I need to find a modern replacement *.
What is the best option? I'm thinking a small oval fullrange driver, since that's what the radio was made for. I will replace the baffle so the exact measurements isn't an issue. However, I would like to get as good a frequency response as possible. The enclosure is approx. H30, D20, W40 (centimeters), and it is totally open; that is, the back is full of holes, there's a rocking lever switch mechanism sticking out, there are some weird hole for a radio antenna, etc. Questions:
(* The old one was a 15x21 cm oval Isophon with square outline mounting holes, approx. 13.2 cm between the hole centers. I don't think it's possible to find a replacement, and I'd rather go for something modern with better frequency response anyway) |
#2 |
Magneto the Gravity Man
Something like this :-
PIONEER TS-A6813I 6 X 8 CUSTOM FIT SPEAKERS on eBay (end time 21-Feb-11 17:44:32 GMT) andy .
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#3 |
Speakerholic
Maybe a picture or two would help also. There's someone I know with a few of those kinds of drivers. I'll see if he's available.
#4 |
Sounds like you have a radio similar to my AGA.
If you're interested you can check this Vintage AGA Radio - Minhembio forum |
#5 |
frugal-phile(tm)
That particular isophon is not all that rare, don't know if i have a single or not. I do have 2 singles of the larger coax.
I also have at least 2 drawers of smaller ovals. For a modern driver, a car driver designed to mount in the back deck koading into the trunk will likely work best in your open back box. Pictures? dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 | |
Team Thermionic |
#7 |
Elmers white glue is a godsend to paper cone repair if the spider and voice coil are ok ...if not then a modern car driver may be your best option cheaper the better as newer high wattage drivers may be inefficient...
E
"when you open your mind to the imposible, soon you will find the truth...." |
| Oval cabinet | nbullamatsis | Full Range | 4 | 15th May 2010 09:25 PM |
| oval cutouts | mrkramer | Multi-Way | 11 | 25th March 2009 12:50 AM |
| Speaker help rebuilding a console radio | uzor | Multi-Way | 47 | 30th July 2007 02:34 PM |
| Oval cones | AJinFLA | Multi-Way | 2 | 14th July 2005 04:11 AM |
| Oval cabinets | jmikes | Multi-Way | 6 | 11th November 2004 01:23 PM |
| Page generated in 0.09583 seconds (77.10% PHP - 22.90% MySQL) with 11 queries |
