Building a fullrange horn - any advice for a newbie? - Page 3 - diyAudio
Old 9th August 2012, 02:34 PM   #21
Thank you for the comments bear.
While I hear what you're saying I really just can't afford the time to do much testing and developing a specific design (as well as the fact I'd be starting from pretty much zero in terms of knowledge about all that stuff).
So the fact that the designs are there, and fairly easy to build, and also the fact that the Lowthers seem to have been mentioned as having been tried in some of the cabinets, is what attracted me to the Frugel-horn website.
I'm aware that this is not going to give me an ideal solution, but am happy to invest a couple of days building the things at the risk of deciding I don't like the sound afterwards.
In terms of positioning I'm pretty much fixed on what's shown in my initial sketch - this layout is determined already by other things.
As for the wider baffles... I'd be fine with wider baffles, especially if it meant the depth of the cabinets could be reduced a bit. So would be interested in any suitable designs that are wider!
Old 9th August 2012, 02:57 PM   #22
Scottmoose's Avatar
Sachiko was replaced by Haruna when Fostex replaced the FE206E with the FE206En.
I took the opportunity to remove many of the 'generic' aspects included on the site / pdf because as a rule I don't care for stuffing any old driver into a box & hoping for the best. FH3 is an exception since it was deliberately designed to be forgiving & tolerant of a wide range of appropriately sized drive units from the outset. Of course, you can try a Lowther in Haruna, and I would say with a high level of confidence it will do better in that box than in some others since it has sheer size on its side, but I make no promises.
The basic response of the driver is more or less a response that gently droops from a mid point in the frequency range down to either end.
Basically true, but with caveats. Here is the PM5a.
Old 9th August 2012, 03:46 PM   #23
Thanks for the clarification.
Two questions if you don't mind...
1) Are there any of the designs you'd suggest as more suitable for Lowther PM6Cs (including obsolete ones)?
2) The FH3: Any guidance on the closest this can be positioned to a wall at the rear?
Old 10th August 2012, 03:17 AM   #24
frugal-phile(tm)
planet10's Avatar
Designed to be close.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th November 2012, 11:23 AM   #25
xrk971 is offline xrk971  United States
xrk971's Avatar
Originally Posted by bear View Post
Btw, most of the designs you see are with narrow baffles.
This is done for cosmetic and WAF reasons in the main.
The best sound will be with a WIDE baffle.
If you have no constraints, then look beyond the typical compromises that most designs of necessity embody.
_-_-bear
If you want a wide baffle, consider a wall mount flat panel horn like the Cornu spiral. You get bass enhancement from wall, ceiling and floor, no BSC needed, and the open and expansive sound stage that these things have is wonderful for certain kinds of music. An easy way to build the Cornu spiral horn is being developed at this thread that you may want to check out: http://www.diyaudio.com/forums/const...nclosures.html
Oh, I almost forgot to mention the most important thing: the WAF on these things is through the roof!
Old 28th November 2012, 02:44 PM   #26
I believe that the "Big Fun" horn was originally designed for the PM6C.
Old 4th December 2012, 01:32 PM   #27
Jamhorn is offline Jamhorn  Europe
Maybe you can order a tailor mode design (in the style of the sachiko/haruna) to planet10 or scotmoose for your lowther pm6c ?
If they agree of course (and if you are ok with the fees)
Old 7th January 2014, 11:54 PM   #28
Ok - three years on from my first post, I'm finally about to build some speakers.
Going to go with the Kirishima design from the Frugal-horn site.
I'm going to build it from OSB instead of ply... possibly controversial(?) but having done a little reading others seem to have had OK results with OSB. Main reason is cost - I can always rebuild in more expensive materials in the future if I decide it's worth it.
I'm going to put my Lowther PM6Cs in them to start with, and see what happens. Might decide to change to some Fostex FE206En (that's what's specified for that design) if the Lowthers don't seem to be OK.
The only other modification I'll make to the design will be to smooth out the angled deflecter at the rear of the mouths into a curve. This is mainly for aesthetic reasons as the insides of the horn mouths will be visible. (Unless someone tells me this is a really bad idea for some reason!)
I've got most of the bits cut and will start on putting it together tomorrow.
I'll post some photos as I go along.
Old 8th January 2014, 01:26 AM   #29
larryldspkr's Avatar
Beware OSB is NOT flat! It will be a nightmare trying to fit all those pieces. Particle board is flat and reasonably inexpensive! I have used OSB, not fun and NOT worth the savings.
Larry
Old 8th January 2014, 09:02 AM   #30
Larry
Do you mean it's not flat as in it has a slightly uneven surface, or as in it can be warped?
I've used OSB a fair bit for other stuff and haven't had a problem. I've found it to be much less prone to warping than plywood.
As for the slight unevenness of the surface; I'm using a gap-filling adhesive to make sure there aren't any small voids along the joints.
fullrange double horn hm Full Range 22 9th September 2013 04:48 PM
Newbie recommendations/ fullrange consideration nathanjh13 Full Range 7 13th July 2010 09:38 AM
Newbie needs advice on big horn subwoofer pdq2 Subwoofers 6 18th January 2008 10:28 AM
new fullrange horn hm Full Range 0 6th April 2006 09:17 PM
Help/advice newbie building dipole surrounds jake_vdb Multi-Way 3 6th February 2004 09:13 PM
Copyright 1999-2017 diyAudio
