Here is the cab I'm going to build... unless someone screams NO! - Page 2 - diyAudio
Old 12th January 2012, 01:27 PM   #11
Shiva5 is offline Shiva5  United States
What would I have to consider if I moved the port to the back? Or maybe to the short, front wall?
Old 12th January 2012, 02:33 PM   #12
GM is offline GM  United States
GM's Avatar
It just needs some unobstructed air space to any reflective parallel surface.
If they were mine, I'd fire the port out the bottom and experiment with the speaker/floor gap to maximize port efficiency. This will get the driver up closer to ear height or if too high for your liking, allow it to be positioned lower in the cab to reduce the amount of internal damping required.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
212 guitar closed back cab build Yanoplathizo Multi-Way 2 21st December 2009 11:56 PM
Guitar cab build! Yanoplathizo Full Range 4 21st December 2009 09:18 PM
how to build a bass bend/scoop cab Javalon22 Subwoofers 1 5th January 2004 04:28 PM
I want to build an amp cab chrislawrence42 Instruments and Amps 3 29th December 2003 09:31 AM
need some plans to build sub box for x-cab truck Ronnie Multi-Way 0 31st December 2001 11:30 PM
Copyright 1999-2017 diyAudio
