First time build with GRS "Bofu clones" - Page 3 - diyAudio
Old 14th February 2011, 11:34 PM   #21
phin586 is offline phin586  United States
The sub could be an option. That would require another amp though. I'm going for a low price point here.
What to do, What to do.
Old 15th February 2011, 01:47 AM   #22
GM is offline GM  United States
GM's Avatar
Originally Posted by phin586 View Post
I don't believe I was replying to you but rather just speaking in general.
Coming 'hard on the heels' of my response, it sure seemed like it.
Anyway, I see you showed some interest in a MLTL variant, so guess it's time to start developing some for the GRS.........
T/S max flat MLTL:
L = 50.75"
WxD = 150.54"^2
zdriver = 19.71"
zport = 47"
dport = 4"
Lport = 2"
All dims are inside (i.d.) and approximate. Sim is lightly damped: http://www.quarter-wave.com/Back_Door/Box_App_Notes.pdf
Fb = Fs MLTL with 2.5 ohms series resistance (R) to show the vintage bass response to expect with a SET amp:
Same as above except........
dport = 6"
Lport = 0.75"
More to come as time permits.......
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 15th February 2011, 02:26 AM   #23
Ok. Perhaps I'm a little more over my head then I may have anticipated. Being as I'm not quite sure what WxD is and I'm not quite understanding some of the lingo. I'm going to definitely keep doing some more reading before i start a build. Perhaps i'll go with a simple ported design to get things going.
Old 15th February 2011, 02:53 AM   #24
Ty_Bower's Avatar
not quite sure what WxD is...
Width by Depth, in square inches for this case.
Old 15th February 2011, 02:56 AM   #25
Gotcha. Google has been a solid 2nd runner up to the knowledge in this thread. Thanks so far guys. I'm starting to get my head in the right place to tackle this, I think.
Old 15th February 2011, 03:57 AM   #26
Tom V is offline Tom V  United States
That looks nice! Flat to the low 30's and a box that is easy to build and doesn't take up much floorspace.
Put it on feet and have the vent out the bottom? Use a slot port on the front Pensil style?
Old 15th February 2011, 04:03 AM   #27
frugal-phile(tm)
planet10's Avatar
Originally Posted by GM View Post
T/S max flat MLTL
drawing. Cross section aspect ratio and driver/port horizontal position use golden ratio
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th February 2011, 04:20 AM   #28
GM's Avatar
Works for me, thanks! Even has my preferred wide baffle! Might as well add your default driver brace to finish it off.
GM
Old 15th February 2011, 04:29 AM   #29
GM's Avatar
Thanks! A good starting point anyway, such alignments often sound a bit boomy in-room, so may need some damping in the bottom to roll off the bottom end at bit and need some baffle step compensation (BSC) to tonally balance it out: General Speaker Related Articles
Yes, or a nice massive plinth like Bob Brines does: Brines Acoustics
A high aspect ratio slot can be used, but will have to be derived empirically.
GM
Old 15th February 2011, 06:30 AM   #30
col is offline col  Australia
col's Avatar
>1) Lower my power consumption.
If you haven't yet purchased the amp it might be worth considering one of the HiFiMediy TK2050 boards, maybe a T1 with a Meanwell SMPS. Being class D they use less watts when driven and if you get one that is rated for 2 x 60W it will have very low idle consumption. I have a T1 and it draws less than 8W when idle.
col.
http://www.minirig.org.au
Pioneer 8" BOFU BIB Variac Full Range 218 17th May 2016 12:39 AM
Super simple RLH for 8" GRS brsanko Full Range 9 15th January 2011 10:39 PM
Ebay "clones" PCB 807tubenut Tubes / Valves 12 5th August 2010 12:14 AM
snow48 cheap gigawork "clones" - anybody tried? Galgo Digital Line Level 2 11th June 2010 10:37 AM
Pics of my diy proac 2.5 "clones" Kermit Multi-Way 71 21st November 2002 01:20 PM
Copyright ©1999-2017 diyAudio
