Old 13th February 2011, 01:36 PM   #1
Default Help please with these bxhxt
Hello
I would like to ask for help about these "bxhxt"
I'm interested to clone these speaker for myself .
Here are some technical spec
technical specifications
Typ Fullrange Club
Description DV8 C
Dimensions bxhxt (mm) 300 x 910 x 300
Load capacity 90W RMS
Max. SPL 95 dB
Frequency range (Hz) 30-20.000
Impedance 8 Ohm
Loudspeaker 8" ( 200mm)
Beyma 8BX
Weight 18kg
More information here.
Benk Cube Diffuser Lautsprecher Systeme, Speaker, don´t panic, case manufaktur
My question about the dimension , the 300x910x300 mm is inside or outside dimension??
It is very important if I want to get the right bass!
If some one has some idea please help with.
One of my fried made some calculation, I need 65L BR to get 30Hz, but he advised these Beyma 8BX is better in closed enclosure not so good in BR!
Thank you.
Greetings gabor
Old 13th February 2011, 04:12 PM   #2
Default Beyma 8BX
Hello
I'm also open to another type of encluse. First time I try to use one point source speaker.
Aldo these coaxial I believe those people can help who has experience with Fostex, Nirvana etc speakers
The Beyma 8BX data
General descriptionThis loudspeaker is a single unit, two-way system, comprising of an 8” bass driver and a concentrically mounted tweeter. This provides a single point source and reduces phasing problems in the crossover region. The bass unit features a 1”3/4 (40 mm.) voice coil attached to a polypropylene cone and copper ring on the pole piece. This provides a smoothly extended frequency response up to 7 kHz, with reduced harmonic distortion. The compression tweeter shows excellent efficiency and fast response to transient attacks.
Key Features
- Considerable power handling: 100 w AES (low frequecies) and 20 w AES (high frequecies)
- Combination of a 8" bass loudspeaker and a compression tweeter
- L.F. Unit: 1.5" (38.5 mm.) aluminium voice coil
- H.F. Unit: 1" (25.8 mm.) copper voice coil
- Aluminium diaphragm tweeter
-The concentric mounting reduces phasing problems in the crossover region
- Linear and coherent response
Technical Specifications
L.F. Unit
Nominal Diameter 200 mm. 8 in.
Rated Impedance 8 ohms.
Minimum impedance 6.8 ohms.
Power capacity 100 w AES
Program power 200 w
Sensitivity 92 dB 2.83v @ 1m @ 2p
Frequency Range 25 - 8000 Hz
Recom. enclosure vol. 20 / 60 l 0.746 / 2.24 ft3
Voice coil diameter 38.5 mm. 1.5 in.
Magnetic assembly weight 2 kg. 4.4 lb.
BL factor 7.3 N/A
Moving mass 0.023 kg.
Voice coil length 14 mm.
Depth 120 mm. 4.72 in.
Air gap height 6 mm.
X damage 20 mm.
H.F. Unit
Rated impedance 8 ohms.
Minimum impedance 6 ohms. @ 4 kHz
Power capacity
20 w AES
Frequency Range 3- 20 kHz
Sensitivity 102 dB
Voice coil diameter 25.8 mm. 1 in.
Flux density 1.4 T
BL Factor 4 N/A
Dispersion 90º
Al do I like the Benk Cube speaker I'm open to any advise.
Greetings Gabor
Page generated in 0.08143 seconds (73.21% PHP - 26.79% MySQL) with 10 queries
