Old 11th February 2011, 03:18 PM   #1
kazoo is offline kazoo  United States
Default Need some help: home theater speakers
Hi guys,
I was thinking of making some home theater speakers using full range drivers. Between the kids and dogs I need to get rid of my towers. I was thinking of bookshelf speakers or small enough speakers that can be put on a shelf or hang on the wall. I want to create 5 of these and use a 6" or 8" driver. I would like these to sound big and have good off axis response. I know a lot to ask for but does anyone have any good plans? Any suggestions would be much appreciated.
Also I do have two 10" subs to take care of the low frequencies.
Thank you.
John
Old 11th February 2011, 03:45 PM   #2
Scottmoose's Avatar
Bit of an awkward set of requirements, that. Good off-axis performance isn't common for widebanders larger than 4in or so & reaching THX / Dolby levels even less so. The new Dayton 8in might do, but it's midband & HF could need some reigning in. The Alpair 12 might be another option; it should have better dispersion than the Dayton.
Old 11th February 2011, 04:49 PM   #3
hm is online now hm  Europe
hm's Avatar
Default kazoo
look my satellites Flute, Trumpet, Schalmei you can also hang them
from the ceiling, look my HP with measurements and feedback
http://www.hm-moreart.de
Old 11th February 2011, 05:39 PM   #4
Hi Scottmoose,
I just dont want them to sound small that is why I said 6" or 8". If you think a smaller full range would be better then let me know which one. I have not been here for a little while so I am not sure about the new drivers that have been developed. I have used fostex before and TB. I was just looking around at some commercial bookshelfs and I think I got sticker shocked. The range is $650 - $2000, and that is for a pair. I would not mind paying that if I knew I was not getting $100 worth of drivers. So I just want a speaker that will give me a great soundstage and not sound small. So I was thinking something like the ZU Audio line where they use a full range with a tweeter for the top end.
Just looking for good sound. Thanks for the help.
Old 11th February 2011, 05:42 PM   #5
Thanks HM,
I will check them out.
Old 11th February 2011, 06:11 PM   #6
Scott,
How about the Double Bass Reflex for the Alpair 12?
Old 11th February 2011, 06:38 PM   #7
Scottmoose's Avatar
It's been well recieved by builders -here's one chap using a pair in HT. What is the Hi-Fi sound that I've read so much about?
Old 11th February 2011, 06:46 PM   #8
chrisb is offline chrisb  Canada
This won't be a quite & simple post, but hopefully will provide some insight to my own particular approach regarding a small HT rig.
One of several projects that I'm juggling right now is somewhat similar to yours, although not with the constraints that as Scott notes could somewhat complicate the matter. That means that I am able to get away with floorstanders for the front L&R.
Previously I was using Fostex FE167E in the large floorstanding Fonken enclosures for 2 channel only, and without the support of woofer(s) (I can't quite get around calling a LF driver that rolls in between 60-100 a "sub"). But after breaking down and trying one of the newer generation of affordable HT receivers ( in this case Denon AVR1610), I realized a few things;
As much as I love the sound of the Fostex FE drivers with a low to moderate power tube amp for music only, or with the old Rotel RB850 when driven from the analog line out of the cable box, I found them too aggressively forward and rather fatiguing on the Denon, and even with the "benefit" of enhanced synthesized effects of the DSP they lacked the transparent acoustics and soundstage of well recorded music. Of course while it can certainly fill a much larger space than it occupies ( 320 sq ft) to more realistic levels than I need, this system won't be used for "serious" music, so the acoustic limitations of the electronics will be swamped by the primary visual sensory input.
While not as critical for non-processed 2 channel music only, for multi-channel movie etc soundtracks (even those synthesized ) the center channel speaker is the most important in the front row. Even though it will likely be bandwidth limited by programming, I'm convinced it should be as close to performance capabilities of the L&R mains as size restrictions of its physical location will allow. IMO it should use the same model driver(s) as the flanking mains.
For a modest size room, I think a small dimension but high performance full range driver such as the current Mark Audio models can answer a lot of the conflicting requirements of a multichannel system.
In my case the solution was Alpair7 for the front row - Pensils for the mains and small horizontally oriented version for the center (exact details / dimensions still underway).
Bass will be handled by a pair of triangular corner mounted dual woofer enclosures powered by separate amp. It took only a few minutes of listening to verify that multiple small woofers work much better in this system than a single. If budget and room layout would permit, I'd go for at least 4.
If you absolutely can't find room for a compact pair of floorstanders (when built with 3/4" material, the Pensils require .44 sq ft, and stand 37" tall, less any auxiliary base/plinth), then no doubt there are several good bookshelf designs that could work. The only other enclosure in which I've yet heard the A7 is the Mar-Ken, which is not an easy build and could be a bit large for a bookcase, for which the more conventionally shaped "GR" design might be better suited.
http://homepage.mac.com/tlinespeaker...v91-090810.pdf
Unless you're able to absolutely dedicate the room furnishing and layout for a "serious" surround system, regardless of its size, or that of the speakers etc., the surrounds can be the hardest to implement. That was certainly the case in previous incarnation of my room, and only my wife's recent concession of "it's your room now, honey" prompted me to pursue the issue. Even so, the shape of room, door openings and staircase can present interesting variables for the design calculus - so there's no such thing as size fits all.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 11th February 2011, 06:51 PM   #9
Why not just attach them to wide bases if tipping is the issue?
Old 11th February 2011, 08:03 PM   #10
Its not just the tipping. Its the moving, scratching, poking, and that damn coutch in front of one. Thats life, I just don't have enought room, or a good room to have a home theater, so trying to figure something to do with what I have.
I like building speakers, so just looking for somethig that will sound good and fit.
DIY cheap home theater speakers. imperfectcircle Multi-Way 3 15th January 2007 03:51 PM
Pair Linear Phase Stereo Floor Speakers/Home Theater ! dale cooper Swap Meet 0 17th April 2005 01:54 AM
Best $800 on home theater speakers? CZ Eddie Multi-Way 9 9th December 2003 09:58 PM
Page generated in 0.30397 seconds (42.34% PHP - 57.66% MySQL) with 11 queries
