Anyone built the Decca Corner Horn (TQWP)?
Old 17th February 2011, 09:13 PM   #11
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
hey, DrBoar
sorry, but I had to remove the pictures
can I please ask you to resize them, or post as attachments
moderation
Old 9th March 2011, 08:36 AM   #12
DrBoar is offline DrBoar  Sweden
DrBoar's Avatar
Here are the scans as attachments I did not find the attachment icon in (you can click the arrow next to the 'Attachment Icon' and select it from the list.) but I hope this will work
Old 9th March 2011, 03:57 PM   #13
R.I.P.
The scans are unreadable.
Use the paperclip icon to add attachments :
Attachment Key
Filetype.Max Filesize.Max Width.Max Height
bmp......195.3 KB.....6200......2800
doc......195.3 KB......-.........-..
gif......195.3 KB.....6200......2800
jpe......195.3 KB.....6200......2800
jpeg.....195.3 KB.....6200......2800
jpg......976.6 KB.....6200......2800
pdf......195.3 KB......-.........-..
png......195.3 KB.....6200......2800
psd......195.3 KB......-.........-..
txt......195.3 KB......-.........-..
zip......976.6 KB......-.........-..
rgds, sreten.
Old 9th March 2011, 04:31 PM   #14
vitalstates is offline vitalstates  United Kingdom
vitalstates's Avatar
Attachment Key
rgds, sreten.
am I missing something.....they're perfectly readable from here, and a good read as well. Thanks for posting.
Ed
There is nowhere you can be that isn't where you're meant to be
www.vitalstates.org
Old 9th March 2011, 05:43 PM   #15
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
No problems reading the scans at this end either.
Old 10th March 2011, 07:28 AM   #16
grindstone is offline grindstone  United States
grindstone's Avatar
Default my head hurts
umkay, first look trying to grok and unclear at terminus.
Fig6A.
voight-ey expanding closed section one,
contracting section two to driver with ??? constriction,
back to voight-ey expanding section three,
then big step-expansion down to base where
happens.
a "port" sorta half the base open into a shelf-port formed by the two 1" high base rails (and exhausting to floor/wall boundary)? two little mass loads?
trying to wrap my head around what the front driver excites. Say the box bottom is sealed for this imaginary scenario. If the thing is pushed tight to a corner, it's almost an external horn with offset driver. Now, if the backwave radiation is coupled to it, too, well, my head hurts.
really grateful for the scans, btw, thanks! (the GA4 hifi amp has rotatable transformers for minimizing hum--sweet
Old 10th March 2011, 07:33 AM   #17
R.I.P.
Ed
I must be missing something, all I can seem to access is the thumbnails.
rgds, sreten.
Edit : I was missing something, you need to expand them before saving them .....
Old 10th March 2011, 08:21 AM   #18
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by grindstone View Post
umkay, first look trying to grok and unclear....
Driver faces a corner
maybe quick & nasty visualization will help
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th March 2011, 09:57 AM   #19
R.I.P.
Having had a good look at the drawings, I can say they have been simplified
somewhat compared to the one I had, no doubt for ease of construction.
I recall the internal partition being more complicated, giving an overall
larger taper/expansion rate, this being built mainly in the angled section.
I did lug it around somewhat, no way was it all 3/8" ply (see previous).
Hi-Fi News and Record Review published a reworked version, using
a Richard Allen twincone I recall, perhaps someone can scan that ?
Not sure about the driver, not the CG8T I recall, was a low Qts version.
rgds, sreten.
A minor detail, think the back 1" should be 2 x feet, not a continuous strip.
Old 10th March 2011, 06:18 PM   #20
DrBoar's Avatar
I have a decca postscript were they state that readers have showed interest in using 12" drivers and that even if HFN thought that the 8" was better they would later publish a 12" version.
The end of the pipe is a mess were the effective area is affected by the feet sinking into the carpet if any...
I would rather use a solid floor in the cabinet, a corner reflector towards the front and the vent opening at the lower end of the 10" by 26" piece
Anyone built the Decca Corner Horn (TQWP)?Hide this!Advertise here!
Why could corner horn not be this simple? mashaffer Subwoofers 17 2nd December 2017 10:42 PM
Corner Horn tinitus Multi-Way 30 13th December 2006 11:10 PM
TQWP/horn - is it any good? Nuuk Multi-Way 6 23rd July 2005 06:28 PM
TQWP, Onken, BL Horn AlexanderS Multi-Way 0 23rd March 2005 09:15 AM
1/4wave corner horn scan? mikee12345 Multi-Way 14 11th April 2003 12:46 PM
