Anyone built the Decca Corner Horn (TQWP)? - Page 3 - diyAudio
Old 11th March 2011, 05:06 AM   #21
grindstone's Avatar
Default verified head still hurts
thanks dave, drboar, all. lotta complicated interactions...eek. hmmm. if the port is cut in the front instead of the bottom, maybe it gets closer to freddy's wheelhouse yet another great circle of well-coupled acoustic reactances...reflections at all the non-smooth transitions, pipe modes. yet another fascinating indulgence in a realm packed with the things. cacophony of honking exceeds my grasp to hold in my attention. seems a job for summer, power tools, and beer. still numb, and still grateful for the scans and the sharing.
Old 27th August 2012, 10:26 AM   #22
DrBoar is offline DrBoar  Sweden
DrBoar's Avatar
OK now it links to the images so the page does not overload.
http://i360.photobucket.com/albums/o...DeccaHorn1.jpg
http://i360.photobucket.com/albums/o...DeccaHorn2.jpg
http://i360.photobucket.com/albums/o...DeccaHorn3.jpg
http://i360.photobucket.com/albums/o...DeccaHorn4.jpg
Old 30th August 2012, 01:49 AM   #23
frugal-phile(tm)
planet10's Avatar
Thanx Dr. I cleaned those up and made a pdf
http://p10hifi.net/forum/RWest-Build...orner-Horn.pdf
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th August 2012, 06:14 AM   #24
devilsindetails's Avatar
Thanks fellows....love this kind of archival info.....
"A problem left to itself dries up or goes rotten. But fertilize a problem with a solution--you'll hatch out dozens." (N.F.Simpson)
Old 30th August 2012, 09:56 AM   #25
Colin is offline Colin  United Kingdom
HFN produced a more modern variant in the 1980s which was designed to be placed alongside a sofa - the idea being they acted as side tables either end of the sofa and you sat opposite them. No corners involved and the drivers and horn mouth faced forwards, so the entire enclosure was longer than tall (a corner horn laid on its back).
It used KEF drivers and had a mechanical filter part-way along to damp the driver. This was a plain partition with a grid of holes drilled in it.
I think Ralph West commented on it, mentioning that the drivers required damping in the horn, compared to older drivers.
Sorry, no idea of the article date or title except that they were referred to as 'Chairsides' and another variation was produced using a single driver Elac.
Old 31st August 2012, 07:03 PM   #26
DrBoar's Avatar
I have that issue, sadly due to spousal pressure the HFN &RR are stored in the attic and its hard to get to them. Late 70s or early 80s. I do not think HFN&RR have had much of DIY in the last 20 years. But I think they are a different kettle of tea with those forward facing drivers. The Decca Corner Horn is more rellated to the ACE horn, a Voigt pipe with upward facing driver and the Rogers horn from the 50s that had a upward facing Lowther unit. This was more of a true horn but with a unusally large chamber and a styrofoam membrane across the mouth of the horn, as I reacall.
HFN &RR also had the Paraline were the driver faced the wall, the long enclosure was either standing or lying sideways with quite long legs underneath them.
Then there was the Basset a single fold Voigt pipe using four 8" Elec drivers and a damping consisting of a back of muslin stuffed with wood shavings! This was used as a subwoofer with an active crossover.
Old 1st September 2012, 02:17 PM   #27
dai is offline dai  Wales
Send a message via Skype™ to dai
I have the origonal booklet FIVE SPEAKERS published by miles henslow which
has tricolumn decca corner 12 inch decca corner paraline and corner concrete
horn designs The only one I have built is the corner horn but this was over 40 years ago
If anyone would like to see any of the articles I will try to post them
All the designs except the corner horn were based on voigt s quarter wave design
regards richie
Old 2nd September 2012, 03:13 AM   #28
regards richie
Hi Richie...I would love to see them!
Old 2nd September 2012, 10:16 AM   #29
Hi devilsindetails
Is there any particulare design you are interested in because there are 78 pages and I
do not know about the leagality of posting the whole thing and whether DIY AUDIO
permits this If you would like a copy of the whole book and no one else is interested
I could photo copy it and post it to you otherwise perhaps one of the moderators
could give me some guidance
richie
Old 2nd September 2012, 05:43 PM   #30
Hi devilsindetails
richie
Hi Richard...Yes that would be a daunting task, indeed...let's see if there is any other interest first...with so much to do and so little time for all of us to do it in... unless the broader DIY community is interested I wouldn't want to monopolize your time. My interest in the designs is more general.
Perhaps after I've done some more research on this article and the designs I can contact you regarding a specific query. Thanks so much for the kind offer...much appreciated
Why could corner horn not be this simple? mashaffer Subwoofers 16 5th August 2014 08:55 AM
Corner Horn tinitus Multi-Way 30 14th December 2006 12:10 AM
TQWP/horn - is it any good? Nuuk Multi-Way 6 23rd July 2005 07:28 PM
TQWP, Onken, BL Horn AlexanderS Multi-Way 0 23rd March 2005 10:15 AM
1/4wave corner horn scan? mikee12345 Multi-Way 14 11th April 2003 01:46 PM
Copyright 1999-2017 diyAudio
