The Minimus 7 solution - Page 4 - diyAudio
Old 12th August 2011, 01:32 PM   #31
rongon is offline rongon  United States
rongon's Avatar
Originally Posted by rhapsodee View Post
I'm tempted to buy the same TB woofers for my Minimus 7. Do you have a graph of the response showing the 7k Hz peak? It looks very smooth on the graph published in Madisound / PE.
If you don't mind sharing details of the Zobel network that you are using?
Qualitatively, does the TB woofer full range sound better / worse than the original Minimus 7 woofer + tweeter with the original ragged response?
Thanks!
The response graph in PE site is zoomed out and overly generalized. It makes the driver response look smoother than it really is. Look carefully at the +/- dB scale (vertical scale).
I used an online calculator to get the values for the Zobel network. Speaker Zobel / Impedance Equalization Network Circuit Calculator
I found the sound of the TB driver to be peaky and ragged in the upper mids to lower trebles. Not much going on above 12kHz, at least as far as my old ears can tell. I'm not getting much of an "airy" response from them.
Also, I'm getting no bass at all. My idea was to use them in a sort of "FAST" arrangement, sitting on top of a pair of old KLH 6 cabs with the tweeters removed, used as the bass speakers. This would be bi-amped with a little 8wpc EL34-triode tube amp for the TB's and a Hafler solid state amp for the bass. But the TB drivers need some taming before I get that far.
If you're looking for a woofer to replace the original in the Minimus 7, then I'd say this model TB ain't it. No bass at all in this cab.
Minimus 7 refurberations... Stuart Easson Multi-Way 44 4th November 2010 04:47 PM
Need help with Minimus 77 j beede Multi-Way 0 12th May 2010 03:23 AM
Realistic Minimus-7 how to Zaffer Multi-Way 21 14th September 2009 05:51 PM
Minimus-7 retrofit fireman Multi-Way 13 5th May 2008 04:14 PM
Minimus 8 Smokehouse Bob Full Range 8 2nd December 2007 06:57 PM
Copyright 1999-2017 diyAudio
