The Minimus 7 solution - Page 2 - diyAudio
Old 27th May 2011, 07:22 PM   #11
frugal-phile(tm)
planet10's Avatar
A normal vent will raise the Q. An aperiodic vent can lower the Q. What is the volume of the box?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th May 2011, 07:47 PM   #12
IG81 is offline IG81  Canada
IG81's Avatar
Most of the M7 1218 woofers I measured have an Fs~49Hz and Qts~0.31 (check out their hefty magnet!). Both a low Fs and Qts is the way to get away with a small sealed box. These TB will definitely sound different in there. The normal M7 Qtc is somewhat under 0.707 IIRC. The TB's might give the illusion of more bass if there is a bump in the response, but the original woofers will go deeper and be smoother.
M7 Vb ~1.8 liter IIRC. Makes sense if I sim that with the measured specs I have for 1218. An aperiodic vent will lower the Q, but there will now be no semblance of bass.
IG
Old 27th May 2011, 07:51 PM   #13
von Ah is offline von Ah  United States
von Ah's Avatar
I was using them daily in my office until I started breaking in 4 EL70s (free-air) in their place a few weeks back. I recall seeing that high-Q when playing with WinISD... But my cabinets are actually the 'Optimus Pro7' which have a port in the back.
The port is ~3/4" diameter and ~2 5/8" deep, which nearly touches the back of the tweeter magnet...
The cabinet is 1.5-2 Liters.
I thought they sounded fantastic and well balanced from ~150 Hz up. While breaking in these EL70s, I've brought back the foobar Electri-Q EQ to dial them in to taste (roughly 3-5 db cut from 400 to 7k). The Minimus 930s were run without any EQ.
Note I use a 10" powered sub under my desk in this arrangement. So I haven't really cared about true bass response from these. I plan to return the 930s to the desk after I move ahead on building the Castle EL70 system.
Old 27th May 2011, 08:10 PM   #14
frugal-phile(tm)
planet10's Avatar
It wouldn't go as low, but a vented (or sealed) Alpair6M would fit that box (with better mids & top). Vent might need to be external thou if one aims for max bass.
dave
Old 31st May 2011, 05:32 PM   #15
rongon is offline rongon  United States
rongon's Avatar
Originally Posted by planet10 View Post
A normal vent will raise the Q. An aperiodic vent can lower the Q. What is the colume of the box?
dave
I assume you meant to write 'volume'...
Somebody wrote that the internal dimensions are (in inches) 7 x 4.5 x 4, which equals 126 in3, or about 2 liters. I got that number off the web, so can't vouch for its accuracy.
Would like to know more about aperiodic venting. Is that the one the old Dynaco A25 used, basically a port covered with acoustically absorptive material? Or is that the dual-chambered cabinet design, as in the old Dynaco A40?
With the Tang Band W4-930SF in such a tiny cabinet, I imagine I'm looking for a way to lower the Q from that of a sealed box.
- Ron
Old 31st May 2011, 06:00 PM   #16
rongon's Avatar
IG
Thanks, I missed your post at first, now I see it...
OK, 1.8 liters sounds more Realistic .
I'm not looking for bass much below 150 to 200 Hz from the M7+TangBand. My hope is to smooth out the low-end roll-off so I can couple these with a pair of woofers using only -6dB filtering without too much problem. I want to experiment with a simple RC x-over network at line level. Perhaps a -6dB hi-pass in the input of my homebrew PP-2A3 amp (6wpc, nice Tango OPTs) and a cathode-follower buffered, -12dB lo-pass to a woofer amp with volume control. I have a 110wpc Hafler MOSFET amp I can use for this, which is more sensitive than my 2A3 amp and has its own input level controls.
High volume and big bass are not as important to me as mid and high frequency purity. That's what I like about the PP-2A3 amp.
Once I've figured this setup out, I figure I might try a final version with Alpair CHR-70 drivers and proper cabinets. This M7-TangBand project is a sort of trial run.
thnx
Old 31st May 2011, 06:43 PM   #17
frugal-phile(tm)
planet10's Avatar
Yea, when i was going to high school i was not going to need to know how to type, so took grade 11 math instead of Grade 10 typing.
Yes, fiberglass insulation and rain gutter mesh works well. Or a series of small holes with an appropriate open cel foam covering the holes on the inside. The former is more appropriate for the box we ar etalking about.
You don't want to start with too high a Q, 1.1, to 1.3 is likely a good maximum target.
I think i may try Fountek FR88ex in my spare set of M7 boxes.
dave
Old 31st May 2011, 07:00 PM   #18
rongon's Avatar
I found this freebie online calculator and plugged in the T/S parameters -- http://www.mh-audio.nl/CBC.asp.
Tang Band W4-930SF specsheet: https://www.madisound.com/store/manuals/w4-930sf.pdf
If I put in a 1.8 liter box, I get
Qtc = 1.135
Fc = 169 Hz
F3 = 127 Hz
it predicts a +2dB peak at 216 Hz.
Re: aperiodic loading -- Have to look up how to stuff the cab and how to calculate size of opening(s). It would be nice if one or two 3/8" or 1/2" round holes could work. I happen to have that size hole saw bit.
Old 31st May 2011, 07:02 PM   #19
rongon's Avatar
and then a little Googling yielded this:
Aperiodic loading to lower qt
Old 1st June 2011, 02:39 AM   #20
mondogenerator's Avatar
hahaha REALISTIC....The irony....Just like the ads for 'Mr Muscle'(kitchen cleaner), featuring possibly the skinniest man alive.
I seem to remember the minimus range being sold when i was a child, in Tandy/RadioShack.
Almost ANYTHING should sound better than these did in original form........ I like the Alpair idea though...its a pity those Hivi or aura 3" are probably too small a frame size to fit.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Minimus 7 refurberations... Stuart Easson Multi-Way 44 4th November 2010 04:47 PM
Need help with Minimus 77 j beede Multi-Way 0 12th May 2010 03:23 AM
Realistic Minimus-7 how to Zaffer Multi-Way 21 14th September 2009 05:51 PM
Minimus-7 retrofit fireman Multi-Way 13 5th May 2008 04:14 PM
Minimus 8 Smokehouse Bob Full Range 8 2nd December 2007 06:57 PM
Copyright 1999-2017 diyAudio
