Alpair 12 in OB with 15" - diyAudio
Old 9th February 2011, 12:59 AM   #1
Default Alpair 12 in OB with 15"
HI Mark
you thinks the alpair 12 can take in OB the full range with 300b amp?
ie without the HF filter ,only on the alpha 15" near 125 hz, in my 65x105cm baffle , as I use this for my single supravox
thanks
Old 9th February 2011, 12:51 PM   #2
markaudio's Avatar
Originally Posted by nicoch46 View Post
HI Mark
ie without the HF filter ,only on the alpha 15" near 125 hz, in my 65x105cm baffle , as I use this for my single supravox 215S bicone.
thanks
Hi Nico,
Sure, 300b should work nicely on Alp12. Combining Alp12 with Alpha 15's on O/B should be nice. The Alpha's have a +10dB peak from 1kHz to 2kHz. I recommend filtering this out as much as possible, and experiment with a cross around 200Hz.
Cheers
Mark.
Old 9th February 2011, 02:22 PM   #3
thanks nice !
run free the alpair12 without ony filter is very good news ...
btw great work Mark !!
ciao
Old 10th February 2011, 03:41 AM   #4
skeeter99's Avatar
Ooh this would be a killer setup! What would you use to power the Alpha?
Old 10th February 2011, 04:25 AM   #5
frugal-phile(tm)
planet10's Avatar
I would not use A12 on an OB without at least a 1st order PLLXO.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th February 2011, 04:29 AM   #6
skeeter99's Avatar
Why's that Dave? Will the driver get too much excursion going in the lower frequencies without the cabinet providing the pressure to keep it in control?
Old 10th February 2011, 05:15 AM   #7
frugal-phile(tm)
planet10's Avatar
Yes. And even if that wasn't the case, with the filter you'll have better midrange/top
dave
Old 10th February 2011, 08:01 AM   #8
norman bates's Avatar
yup, what he said.
I like 200hz at 24db LR.
Otherwise you are volume limited. The louder you listen or the more bass, the more modulation / gargle / strained the vocals get.
Norman
Old 10th February 2011, 10:22 AM   #9
this is the challenger ! my hops is that work fine at lower volume....
Dave is 100% right!! but this can apply at all FR...Dave can you test on the fly ??
for 150€ each need to do same work!!
I not like the idea to put a cheaper 80/90 caps in series... my is 200mm with qts of 0.8 93db work fantastic ,but the A12 is quite low , the tube amp lift a bit 0.4/0.5?
manu
Old 10th February 2011, 10:40 AM   #10
Norman ,cutting at 200hz the A7 and A10.2 can do the job and is a two way design with big xover ,sure work fine as Mjk do... but I try do FR +help
there is some A12 ob around , no one want try without filter ?? need beta tester
here the A7 without filter plus tube Alpair 7 Revisited review
Alpair 12 vs Alpair 10.2 and a little Fostex 166 germpod Full Range 4 28th January 2011 04:19 PM
Alpair 10 more forgiving than Alpair 7 & 12 tripathdude Full Range 3 6th November 2010 07:14 AM
15" woofer for OB? grantnsw Multi-Way 39 17th July 2009 02:39 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 03:29 AM
Copyright 1999-2017 diyAudio
