Old 7th February 2011, 03:08 AM   #1
CollinA is offline CollinA  United States
CollinA's Avatar
Default Fostex FE206en EnABL process and other mods
Hello-
I've been surfing diyAudio for a couple years now, and I would like to ask some specific questions about EnAbling a pair of FE206ens. I have treated a pair of the older FE206s, but the the whizzers are all bent out shape by now, and I feel that I could do a better job, since they were the third pair of drivers that I have treated.
I've searched all over diyAudio, and still had some questions left over, so here goes:
1) There is a 10db hump around 10kHz on the older treated drivers. Any way to reduce this besides a filter?
2) Regarding the actual EnABL pattern, is it worth my time to add a middle ring, on the main cone beneath the whizzer? Where?
3) How about on the back of the main cone?
4) The 206s are currently in a pair of Sachikos (which sound wonderful, btw). How much improvement would I see if I EnABL the accessible areas (baffle, mouth, throat, etc.)? Would EnABLing all the internal surfaces/corners offer significant improvement over the currently accessible areas?
5) I was reading about Planet10 using SR-500 for basket stiffening. Since it's expensive stuff, and takes forever to apply, would a layer of powdered limestone/epoxy mix followed by a layer of ductseal offer similar results? Would the SR-500 be better?
6) Mamboni process:
a. How? What shape/size of felt?
b. Is it worth it?
Thank you! I look forward to hearing your responses.
Old 12th February 2011, 12:59 AM   #2
StoneT is offline StoneT  United Kingdom
Bump
Having just bough a pair of these I'd be very interested in comments too.
StoneT
Old 12th February 2011, 03:04 AM   #3
frugal-phile(tm)
planet10's Avatar
There are some pictures of 206/207eN on my kermit thread including recent EnABL2
Pretty much the same story for FE206/207 as FE167 here (althou we are now into EnABL 2)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th February 2011, 06:07 AM   #4
hm is online now hm  Europe
hm's Avatar
Hello,
did you made measurements to control what you have done, did you test other enclosures because the driver need support below 800 Hz that you canīt get by
a basshorn?
http://www.hm-moreart.de
Old 12th February 2011, 07:40 PM   #5
The main issue I would like to address with these drivers (having still not listened to them yet) is the peak at 2.5KHz but i have not seen any info on whether it is addressed by EnABL or phase plugs or just reduces after break-in.
Without it, these drivers would seem to be very nice. I just need to build some cabs and get them out of that delivery box
StoneT
Old 8th May 2012, 04:23 PM   #6
If you haven't found this mod yet...try this. It's a pain in the butt and you have to be careful not to bend the whizzer's but it can be done. Get some really thin foam about 1/8 inch thickness or close to that. Have to probably buy a sheet or find a foam company with scraps. Cut it long enoug to make a circle with the exterior diameter of the whizzer at it's base. About 3/8" to 1//2" wide.(YMMV) Edge glue it together. I used hot melt glue since it sets up fast. Now carefully stretch it over the flare at the end of the wizzer
and move it to the base of the whizzer. It will damp the whizzer to a mild degree. U can adjust the thickness to suit and see what you think. Initially err on the side of to long and too narrow as your practicing placement.
Old 8th May 2012, 05:20 PM   #7
chrisb is offline chrisb  Canada
even simpler, stretch out some cotton batten or fibrous "pillow fill" and loosely stuffed between whizzer and main cone - shouldn't take more than 5 minutes, and friction fit will be more than enough for a taste test
Eminence Beta 12LTA:
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
EnABL How-To for Fostex FE127e and other speakers loninappleton Full Range 359 9th April 2012 08:20 PM
fostex FE206En cone head Full Range 7 6th December 2011 10:06 PM
fostex FE206En fr driver cone head Full Range 3 6th August 2010 09:37 AM
anyone get/analyze (stock Fostex) FE206En? freddi Full Range 24 8th April 2010 06:00 PM
Page generated in 0.10083 seconds (80.86% PHP - 19.14% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
