Alp10.2 in 17literBR
Old 1st February 2011, 07:02 PM   #1
OlavHaal is offline OlavHaal  Norway
OlavHaal's Avatar
Exclamation Alp10.2 in 17literBR
Hi all!
Almost finished with Alpair 10.2 in 17liter ported box. I have to make som small adjustment on the outer finish!
This very revealing couple has been running with low volume for 5-6 days now. Have tried some (carefully) higher volumes - and it is a thrill to experience the openness and involvment that this couple gives!
I have made the back of the boxs removable and I have made ports in a way that it can be adjusted. My photos will demonstrate this - if you`re interrested?
Got a 10-12 fairly good photos. I will include 2 now - and I have a schetch of my building/design!
I was never expecting the Alp10.2 was to make a major leap in sound from my Fonken w/fr125sr and ERT26 - but they are making great advancement toward just that goal.
So Cowboy Junkies is just here in room when the Alp10.2 is making them stunningly alive1
Thanks again Mark!!
Olav
Old 1st February 2011, 07:28 PM   #2
vinylkid58 is online now vinylkid58  Canada
vinylkid58's Avatar
Interesting looking boxes. What exactly is it, if you don't mind me asking?
jeff
Old 1st February 2011, 07:41 PM   #3
OlavHaal's Avatar
Smile Yea - as wanted!
Hi!
They are made from Oak - 18 mm. In Norway they are called HobbyPlates. I think they are laminated and glued. Very stiff - and somewhat harder than birch!
Gives a very sturdy "think" sound when you knock on it! Birch is softer and a bit darker in respons!
But the sound from Alp10.2 in Oak is magnificent!
I hope my English isn`t too bad - been a while since schooldays......
Olav
Old 1st February 2011, 08:47 PM   #4
vinylkid58's Avatar
Similar to what we call "Butcher Block" here.
Not surprised you like the A10.2's.
Pretty good actually.
You live in a beautiful city BTW.
jeff
Old 2nd February 2011, 05:13 AM   #5
OlavHaal's Avatar
Yea!
You mean I like them because they`re made of oak - or because they are perfect with acoustic music like Cowboy Junkies and Calexico?
And Cow... is from Canada - can also be an alternative!
Anyway - great sound - both from band and in such good drivers!
Greetings to all
Olav
Old 3rd February 2011, 03:25 PM   #6
OlavHaal's Avatar
Red face Plans & pics
Hi to all!
Here are some more pics + the plans I made. I made the ports in 1 lenght and can tune it if I want - by adding short plates further back against the wall. The bracer on the driver is glued to the sidewalls and with additional bracers against the fasteners that the removable back is schrewed into.
Got som ideas from T.Gee`s Solo103 and the Fonken for sr125 and MarKen to Dave(Planet10). Thanks Dave!
In my living room(9 m long and 5-6 m width) the volume and dynamic is VERY good. I still don`t play very loud - family and else is some reason - but these pleasant-sounding devices fills my room like I never imagined!
One little question remains: My HarmanKardon HK980 is very dynamic(2*80W and 80 Amp) - but if I want to build an amplifier - what would that be: Tube, D, T or a hybrid?
If someone know about a brand that isn`t to expensive or to diificult - I would be very grateful!
I looked at Elekit - but the easiest to build is not for 230 V. And I don`t know if it is wise to use a converter from 230-110V? Because maybe the transformer need 110V.
All the best to everyone.
Olav
Old 4th February 2011, 04:05 AM   #7
markaudio is offline markaudio  Hong Kong
markaudio's Avatar
Hi to all!
Olav
Hello Olav,
Firstly, many many thanks for sharing your plans and build experiences with DIY audio members. This is excellent work and in the best spirit of the DIYaudio forum - well done!
Re the amplifier question. There's allot of tube and circuit choice. So far I've tried EL34, 6V6, 300B and KT88 in various combinations. Really hard to choice between them. I'd personally suggest keeping to a tube and circuit combination that gives you 6 watts on Class A upwards if you go SET. I recently listened to Derek Shek's prototype Class D, fantastic sound. Hope he takes it into production.
Hoping guys using tubes, Gainclone, Chip amps and newer designs can comment - hope so. Anyone with solid experience also. Might by worth you making a post in the amp section of DIYaudio?
Cheers
Mark.
Old 4th February 2011, 08:31 AM   #8
OlavHaal's Avatar
Default a little more...
Thanks Mark!
Will try your suggestions when it is convenient.
And I have added some more pics to show how I fastened the side-panels to the baffel! With small woodsticks(like the ones that come with furnitures) - drilled holes and used strong glue, so it feels like it has more hold.
And as you can see from the other photo The Alpair is so small(maybe a Pensil next time - if we don`t move to a smaller appartment) - but the sound fills the room at 45 sqmeter even at moderate volum. Just now Golden Heart with Mark Knofler fills the space. The HK980, squeezbox touch, dacmagic is positioned in the middle!
In the other part-corner you see the Fonken(wFr125srErt26)- which is secondary today. But also very good!
Been a very nice experience - building sound thats so good!
Best to all
Best to all
Old 4th February 2011, 09:44 AM   #9
OlavHaal's Avatar
Red face sorry - wrong info
Hi all!
Some misinformation: It is the Bottom and Top-panel that is glued to the baffel with woodsticks!! The sidepanel is glued to top/bottom/baffel after those three is fastened! And without woodsticks(more difficult to keep the holes aligned to each other)
Best to all
Olav
Old 16th March 2011, 02:08 PM   #10
OlavHaal's Avatar
Default Flush driver & tuning
Hi there all!
Have now tuned my speakers to 43Hz, and when I`m using Stereophile TestCD I can hear relative strong output at 50Hz - and a little weaker at 40Hz. No output at 30(as expected). And the 3-dimensionality is much more improved after I made the flushmounted baffle. Like the picture show! And I made some stands from a cheap IKEA support(it costed 12 dollar). Gives a better and more distinct sound!
Now they are nearly finished - need to get a new upper plate on my stand. Oak to keep everything more even!
And the sound is very fullfilling - SingleDriver is king. (Wonder if Alp10.2 in FrugelHorn MK3 is more revealing than this?)
Maybe at a later time......
Greetings to all.
Olav
Last edited by markaudio; 16th March 2011 at 03:08 PM. Reason: Nice pic. Photoshop version added - cheers Mark
Alp10.2 in 17literBRHide this!Advertise here!
