Pensil Pics, lets show 'em! - Page 9 - diyAudio
Old 13th April 2011, 04:12 AM   #81
skeeter99's Avatar
Here's a gorgeous pair from the main gallery:
Old 13th April 2011, 12:27 PM   #82
zman01 is offline zman01  Bangladesh
Looks gorgeous, no doubt...
But if it's a Pensil, where is port at the front?
Old 13th April 2011, 01:32 PM   #83
Went to the main gallery and came across the builder's explanation - the port is at the back.
I am no expert, but shouldn't that change cab characteristics?
-Zia
Old 13th April 2011, 02:41 PM   #84
skeeter99's Avatar
-Zia
Yeah I guess its not a Pensil from the way he explained it. I presumed he just moved the port to the back and maintained the Pensil design but apparently not. Should I remove the pic and link since its technically not a Pensil?
Old 15th April 2011, 02:22 AM   #85
chrisb is online now chrisb  Canada
Default Pensil A7
standard chrisby treatment - lotsa bracing, cherry veneer, magnetic grilles - temporarily under the TV - Alpair7 center, and hiding in the corner, one of pair of dual Eastech woofers
now on sabbatical
Old 15th April 2011, 02:29 AM   #86
doorman is offline doorman  Canada
doorman's Avatar
Really nice clean application, Chris!
Are the front cabinet edges bevelled, (or a photo artifact)?
Don
( you got mail)
Old 15th April 2011, 03:21 AM   #87
Very handsome Chrisb!
I am pretty sure I see bevelling on the front edges.
-Zia
Old 15th April 2011, 03:51 AM   #88
skeeter99's Avatar
Wow those are gorgeous! How does the 7 do as a center? How is your off axis response?
Old 15th April 2011, 04:03 AM   #89
frugal-phile(tm)
planet10's Avatar
There is at least one set of Pensils in Oz, that went ahead because i suggested that mounting the driver on the back (or the sides) should be fine,
You'd probably also be fine doubling the depth, putting a terminus on the back just like the front, mounting a driver on each side & then rotating the box to make the side the front...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th April 2011, 04:45 AM   #90
Originally Posted by planet10 View Post
You'd probably also be fine doubling the depth, puting a terminus on the back just like the front, mounting a driver on each side & then rotating the box to make the side the front...
dave
A sort of Alpair 12 Micro Tower? Only problem is that the tower would become pretty big...
Have you ever tried such a configuration?
My Super Pensil 12.2p Build -With Pics! tlarwa Full Range 12 12th January 2015 05:07 PM
Super Pensil Build with Pics zman01 Full Range 38 9th July 2011 07:23 AM
why does my pics show as attachments? AudioGeek Forum Problems 8 6th July 2004 12:54 PM
Pics from T.H.E. Show in Las Vegas Timn8ter Multi-Way 7 13th January 2004 04:56 AM
pics from 2002 Stereophile show dorkus Everything Else 3 9th June 2002 09:19 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
