Old 31st January 2011, 07:01 PM   #1
Squeak is offline Squeak  Denmark
Squeak's Avatar
Default Line restrictions in horns & pipes
New thread split off from here BiB Vs. iBiB
Originally Posted by Scottmoose View Post
Use what?
:-O
Chokes, reflex tubes at the end of horns, just like you were talking about.
But you do. It's very common. What do you think the type of box that has become known as an ML-TQWT is? A mass loaded tapped horn, that's what.
Yeah, but that's quite a recent "invention" or development. The Metronomes taper for example is, I have a strong inkling, only really good for keeping standing waves/resonance from going, not for horn loading. The exact same thing can be done with just a fiber plug, like in the Altec Aquarius 5 or the EPI Microtowers.
Old 31st January 2011, 07:40 PM   #2
Scottmoose's Avatar
Er, I think you'll find that it's more than a 'recent "invention" or development.' Unless you call the 1940s -'50s recent in terms of home audio? I suspect the boxes GM refered to above were ones he built back in the 1960s. And Olson was employing a slightly different variation back in the late 1930s. There really was just about nothing the pioneers of audio didn't do or explore, digital-era developments in Eq, delay etc. aside.
The Metronomes are technically tapped, mass loaded horns. If a pipe has a degree of positive taper present, then by definition it possesses some 1/2 wave characteristics, ergo, it's a horn.
Old 31st January 2011, 07:42 PM   #3
frugal-phile(tm)
planet10's Avatar
Originally Posted by Squeak View Post
EPI Microtowers.
are just a straight end-loaded TL. The modern ode to microTower, uses mass loading to get lower bass from the same height column.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 31st January 2011, 07:57 PM   #4
Squeak's Avatar
Hey, I didn't say anything about the idea being bad as such, I was implying the 1. The idea is far from commonly used, even though it was once used and has seen a recent resurgence. 2. So there must be some drawbacks. Free lunches are very scarce in audio.
Yeah by definition, but how about in reality? How much horn action is really going on inside the box? Some sure, but not anything near enough to account for the bass coming out.
Old 31st January 2011, 08:03 PM   #5
Squeak's Avatar
Originally Posted by planet10 View Post
are just a straignt end-loaded TL. The modern ode to microTower, uses mass loading to get lower bass from the same height column.
dave
The EPIs use port loading too. Though more a cross between aperiodic and BR (basically just a round hole in the bottom with some fiber stuffing).
Old 31st January 2011, 08:07 PM   #6
frugal-phile(tm)
planet10's Avatar
I owned a pair of the original EPI microTowers, built a set of clones in 1974 (which i still have), and have had at least a couple more thru here since. No ports in any of them. A base plate with as large a circular hole in at as possible, as much to ensure that the bat of fiberglass (the whole length of the line) didn't slip out.
dave
Old 31st January 2011, 08:26 PM   #7
Scottmoose's Avatar
Hey, I didn't say anything about the idea being bad as such, I was implying the 1. The idea is far from commonly used, even though it was once used and has seen a recent resurgence. 2. So There must be some drawbacks. Free lunches are very scarce in audio.
No free lunches in audio, but it never did depart, it's always been lurking around in the background in one form or another. Things move in & out of popularity, but you will recall that until the 1970s, some degree of DIY was considered more the norm than otherwise in high-end audio (or at least a worthy equal). It dropped out of favour for a while, but thanks to the 'net, DIY is now seeing an upsurge in interest once again.
What exactly do you mean by the term 'horn action?'
The degree is immaterial. If a pipe expands toward the terminus, it possess some 1/2 wave characteristics & will therefore be longer for a given Fp than an untapered, or reverse taper horn.
Old 31st January 2011, 08:53 PM   #8
chrisb is offline chrisb  Canada
IIRC, the fibreglass wall damping in the original EPI microtower was held in place by several spring steel strips, and the hole in the bottom plate was as large as possible while still retaining room for the spring loaded wire terminals and provide some structural bracing for the open end.
At the most, acoustical "end load" would be that of 3/4" deep port only slightly less than pipe CSA - which is rather different from the mass load of the Planet 10 designs.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 31st January 2011, 09:02 PM   #9
Squeak's Avatar
But this concept never really caught on to the degree of other ideas. I guess for a reason.
You could put a speaker at the bottom of a bucket and call it a horn, but you will still get very little loading.
Old 31st January 2011, 10:14 PM   #10
Scottmoose's Avatar
Didn't catch on compared to what? As far as I know, variations have been quite popular for decades.
Indeed you could, assuming the bucket was tapered.
Full range recommendation w/ special restrictions... vaughn Full Range 7 5th April 2012 06:17 PM
Wiki Image restrictions DougL Forum Problems 0 29th March 2010 11:01 PM
DC TT supply, need schematic with some restrictions Giaime Analogue Source 1 19th February 2006 03:20 PM
Electronic Church organ Without Restrictions Da5id4Vz Instruments and Amps 3 24th February 2004 05:12 PM
Line Array question (concerning Horns and CTC) Hybrid fourdoor Multi-Way 2 27th July 2003 01:17 PM
Page generated in 0.17471 seconds (61.48% PHP - 38.52% MySQL) with 11 queries
