I’ve been playing around with some inexpensive 8” full range ceiling speakers. You know the type, stamped frame, small magnet, paper cone, cloth surround and a whizzer. They are primarily midrange, being a bit weak in the bass and somewhat thin in the higher frequencies. I won’t be using a transformer.
They do sound OK for public address and elevator music, but I’d like to contour the frequency response a bit to make them more acceptable for FM and stereo. I was thinking of attenuating the midrange by about 3dB from 200Hz/300Hz to 2KHz/3KHz depending on available component values, size and cost. The speakers are 8 ohms nominal, but I measured the resistance and it is 6.5 ohms DC, so I imagine that the impedance around 200Hz would be 6.5 - 7 ohms and then rising gradually from there. I’m not sure what you call the filter, but I’m pretty sure it would be low Q and I’m not sure if you use the Geometric center frequency or the Arithmetic mean when designing such a filter. Anyone know what type of filter I should use, whether it should be series or parallel etc? What it is called and if there are any online calculators out there so I can massage the values. Thanks. |
| Notch Filter Design - Seas L21 (H0955) Breakup Modes:Single or Multiple Notch Filters | dtm1962 | Multi-Way | 10 | 8th February 2010 02:17 PM |
| need help wana change 60-Hz twin-T notch filter to 279 Hz filter | prorms | Solid State | 0 | 9th February 2008 11:38 PM |
| notch filter help | omni | Multi-Way | 14 | 23rd July 2007 01:11 AM |
| Can Zaphs notch filter be used without the BSC filter? | GuyPanico | Full Range | 0 | 21st July 2007 01:27 AM |
| Do I Need A Notch Filter? | noodle_snacks | Multi-Way | 13 | 31st October 2005 01:35 PM |
| Page generated in 0.07322 seconds (75.55% PHP - 24.45% MySQL) with 10 queries |
