Old 31st January 2011, 04:27 PM   #1
steve13 is offline steve13  France
Default TA2020 + Full ranges??
Hi everyone
I was thinking of pairing a TA2020 ("tripath") to some full ranges, possibly Fostex FE126en. Any thoughts, advice, opinions?
I read on this forum that the general consensus is that the fostex plans are not great, however i also need an enclosure which is not too huge (small apartment).
Help would be appreciated
Old 31st January 2011, 04:40 PM   #2
ra7 is offline ra7  United States
The tripath amps sound good with high-eff full rangers, like the FE126En. Go for it. They are a great, economical starting point to hifi sound. Dave or planet10 here will surely chip in with cabinet options. You can check his website too which is great.
Old 31st January 2011, 04:53 PM   #3
mor2bz is offline mor2bz  United States
a tube buffer , tube stage in cd player, or tube preamp will help a bit.
make sure you have battery power for the amp. this makes the bass twice as good. if the sound is too hot listen off axis. for more warmth and tone but alot less treble get a coat of dammar on the cone. my own experience,
mind you. what are you doing for bass support? a woofer crossed over,
a backloaded horn, a sub to augment?
Old 31st January 2011, 04:58 PM   #4
Godzilla's Avatar
Yes, good combo.
Old 31st January 2011, 05:16 PM   #5
Saturnus's Avatar
I've used a FE206 BLH with an TA2020 as my home reference system for years. It's completely off-grid battery powered as the batteries are recharged by a small 15W solar panel.
If you use the smaller Fostex's you might need a tube pre-amp to get the sound right. With the larger Fostex's that's neither needed nor wanted.
Old 31st January 2011, 05:25 PM   #6
Great, thanks for all the advice already..
@Saturnus, what type of enclosure are you using? and what room dimensions?
Good idea about the tup pre-amp, i kind of always wanted to build one anyway.. but will only get onto that later, once all is built and broken in.
I am interesting in the back loaded horn designs, the only problem is i dont really have a lot of space, are there any smaller options?
Old 31st January 2011, 05:51 PM   #7
What kinda batterys are u using? Any thread here on diyaudio?
Regards /Bo
Old 31st January 2011, 06:17 PM   #8
Saturnus's Avatar
Steve13, I just use a slight modified version of the reference design. My listening room is about 18 square meters (~3˝m by ~5m).
danerius, I use LFP cells.
Old 31st January 2011, 06:38 PM   #9
frugal-phile(tm)
planet10's Avatar
The smallest enclosure that provides a load the FE126En likes is the Frugel-Horn Mk3 (Frugel-Horn Mk1 Level 0, is a bit smaller, but performance gains are to be had with the Mk3). If you need a smaller box, time to look at a different driver.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 31st January 2011, 07:00 PM   #10
The frugel-horn mk1 level 0 looks like a decent size, also not too complicated.
I think i might be going with that..
Thanks for all the help everyone
rgrds
Replacing Logitech Z2300 to full ranges! artazzzzzz Full Range 31 23rd January 2010 05:18 PM
TB 2" Full Ranges MiniVanMan Full Range 6 22nd June 2008 03:29 PM
Samco Full-Ranges mod_evil Full Range 2 24th March 2008 04:26 PM
What should I do with these Philips Full Ranges? miccomacho Full Range 6 14th February 2007 04:25 PM
Full Ranges for Rock/Metal juan_caliente Full Range 17 25th June 2005 07:09 AM
Page generated in 0.10546 seconds (79.94% PHP - 20.06% MySQL) with 10 queries
