BiB Vs. iBiB
BiB Vs. iBiB
Old 31st January 2011, 06:33 PM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
BiB Vs. iBiB
IIRC = if i recall correctly.
No one has researched the optimum Karlson slot size. If i ever build one of these (with no corners not any time soon), i would make the slot with drilled holes, start slow, and grow the slot until i was happy.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 31st January 2011, 06:35 PM   #22
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Bet me re the 126. It does if you want to get LF out of it with any semblence of dynamic BW in a back-load.
Anyway, I didn't get chance to do any detailed tests, but like GM, I found under certain conditions the mass loaded tapped horn (BIB) was notably superior; particularly (and as you would expect) regarding their upper corner roll-off. Incidentally, properly executed chokes in horns are nothing new; Harry Olson advocated them back in the late 1930s & I don't recall many complaints about his designs.
Old 31st January 2011, 06:47 PM   #23
Squeak is offline Squeak  Denmark
Squeak's Avatar
Originally Posted by Scottmoose View Post
Bet me re the 126. It does if you want to get any LF out of it with any semblence of dynamic BW.
But there is a limit to how far you can go. IIRC the BIB calc says the minimum horn for a FE126 should be about the 2 m. Going much over that will get you deeper but more attenuated bass and maybe get resonances.
I don't recall seeing many others use it in the meantime. If it is such a fast and easy win win way, why doesn't everyone use it?
Old 31st January 2011, 06:58 PM   #24
Scottmoose's Avatar
I wasn't refering to the BIB. I know its limits well, I was the one who triggered off that monster thread, & did a lot of the text on the 'Zilla site, while GM was the one who came up with a workable T/S based Vb alignment for it. Either way, generally not a good idea to tune below 0.707Fs in it, whatever the driver.
But you do see it. It's quite common in DIY circles. What do you think the type of box that has become known as an ML-TQWT is? A mass loaded tapped horn, that's what.
Old 31st January 2011, 07:39 PM   #25
ziocalepino is offline ziocalepino  Italy
Well, thanks for explanation on Bib and iBiB.
Anyway I do not explain well about area of Karlson hole. In the unique iBiBk plan area is 27 in^2. From where does this value exit?
Old 31st January 2011, 07:45 PM   #26
frugal-phile(tm)
planet10's Avatar
BiB Vs. iBiB
That value was pulled from the air, and choosen small enuff that it could be grown if needed.
Some historical, empirical info suggests that the length of the slot could be as long as a 3rd the length of the entire line.
dave
Old 31st January 2011, 08:03 PM   #27
Scottmoose's Avatar
Yup. From Norman Fulmar's 1952 Patent application (granted 1957):
Old 31st January 2011, 10:53 PM   #28
Scottmoose's Avatar
I was going to add this to the last, but ran out of time. Whatever you wish to call them, an Av=Sd vent on a BIB style pipe horn as GM described & we were discussing before things became diverted can be an effective thing to try.
Old 1st February 2011, 01:36 AM   #29
frugal-phile(tm)
planet10's Avatar
BiB Vs. iBiB
Digression split off to here
Line restrictions in horns & pipes
dave
Old 2nd February 2011, 04:10 AM   #30
GM is offline GM  United States
GM's Avatar
Well you get higher efficiency in a smaller box, and the small BR hump before the LF extension falls off a cliff, that gives the illusion of lower extension.
The trade-off is lack of precision and lack of extended smooth roll-off.
Who said anything about a smaller box? Mine were acoustically quite large and the HR sims adding reverse cone 'tophats' I did were BIBs that were calculated using the BIB Excel WS and had already been built and favorably reviewed by others.
Yes, the roll off is a bit steeper, but again, if tuned low enough it's no where near the big deal you're implying due to our hearing acuity being so poor in the LF where the room dominates anyway.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
BiB Vs. iBiBHide this!Advertise here!
my new BIB (again...) nirvana Full Range 31 24th December 2008 05:13 PM
AJ-Horn & BiB - ar some BiB "parabolic"? freddi Full Range 3 6th April 2007 03:09 PM
Bib...? Fuling Full Range 3 11th March 2007 07:45 PM
