Smallest cabs for each Alpair? Roughly ... - diyAudio
Old 29th January 2011, 03:50 PM   #1
Default Smallest cabs for each Alpair? Roughly ...
A designer friend wishes to build a wall-mounted phone and iPod docking station and place-for-house-keys-and-stuff. I'm steering him towards Mark Audio drivers - he likes the look and I've assured him that he'll like the sound, too.
I think he's OK with using a subwoofer. Perhaps an overly broad question: For each of the new-shape Alpair series, what is the smallest reasonable sealed cabinet volume? I.e. the Alpair 6P and 6M, Alpair 7, Alpair 10.2 and Alpair 12? And perhaps the CHP-70 as well ...
Or alternatively, is there something in the T/S parameters that you can look at to get a very rough estimate of a good cabinet volume?
Thank you!
Old 29th January 2011, 05:56 PM   #2
frugal-phile(tm)
planet10's Avatar
A6M in 1-2 litre sealed. I have a 1.5 litre vented for it as well.
Some SIMs attached (CHR are gen1, gen 2 is much the same)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th January 2011, 11:18 AM   #3
Excellent information! Thanks. Exactly what we need to get started.
The designer had anticipated an internal volume of about 8-18 liters internally. According to this AJdesign box simulator, an 8-liter box could support an Alpair 10.2 pretty well, with a -3dB point of ~70Hz.
Say, what Mac application is that you're using to sim with?
Old 31st January 2011, 01:40 AM   #4
frugal-phile(tm)
planet10's Avatar
MacSpeakerz.... end of life 10+ years ago. Runs in Classic.
dave
Old 31st January 2011, 03:34 PM   #5
Hi Dave,
How would you approach building a FAST system?
I'm still toying with the idea of adding a small'ish sealed box + Alpair7 to complement the 10.2 Pensils. What should be the volume/dimensions that I should be looking at? Would placing this complimentary box on top of the Pensil work?
Edwin
Old 31st January 2011, 08:01 PM   #6
frugal-phile(tm)
planet10's Avatar
My approach to FAST is probably better covered in the Tysen thread.
Take a good Extended range driver -- you are not going to be asking it to do bass, so you can concentrate on MR + HF. Then add 1 or more midbasses -- you want something that goes reasonably low, but that extends up fairly high, i'd suggest up to at least 1kHz.
As with any system, XO is the hardest bit to get right. Since it is in the region of baffle step, cabinet size etc play a direct role. You do have the advantgae of drivers having good overlap, and with a low XO, essentially co-incident drivers, so simple XOs can work. Active certainly makes things easier.
dave
Old 1st February 2011, 02:26 AM   #7
Thanks Dave for pointing me to the right thread. Been searching for it!
Alpair 12 vs Alpair 10.2 and a little Fostex 166 germpod Full Range 4 28th January 2011 04:19 PM
Alpair 12en in BIBen cabinet or Alpair 7 in fonken w/subs tripathdude Full Range 1 7th November 2010 06:04 AM
Tannoy 15" Reds for sale with crossover and cabs (local pickup for cabs) saletel Swap Meet 0 27th October 2006 11:01 PM
Speaker impedance roughly 6 ohms, 2A3 SET... Saurav Tubes / Valves 14 17th October 2004 04:47 PM
Copyright ©1999-2017 diyAudio
