#101 | |
Wow, they're beautiful! I have the same problem with the soundstage as you have, but it's is shifted to the right. That's because to the right there's a corner and to the left there's there door to my room. So nothing i can do about it. But i didn't see you had any corners, and that bookshelf or whatever it was to the right shouldn't affect it i think. |
#102 |
Rullknuffs,
You nailed it. I have a wall to the left and open room to the right. Wow! best teacher is always personal experience in combination with others knowledge and experience. Just learned my first lesson on room interaction. Will raising speakers off floor hurt or help bass? Floor bounce? Within a week or two they will be veneered in curly cherry! |
#103 | |
#104 |
FWIW, it's been my experience that symmetry of speaker placement in relation to corners (or lack thereof) is very helpful, as well as toe-in to reduce imbalance from early first reflections from untreated side wall(s)
Another nifty trick is diagonal placement that I gleaned from this interesting article. Definitely worth a try if you have the floor space to play with. DECWARE - Article about Setting up a Listening Room without Treatments
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#105 |
I have the shifted soundstage problem in my room too. A good old-fashioned balance control helps a lot.
#106 |
frugal-phile(tm)
My room is open on the left with a corner to the right... the sloped ceiling seems to make it a non-issue. With a good recording (and kit) the entertainers almost seem to be floating in the air over the creek on the north side of my house.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#107 | |
![]() Don |
#108 |
frugal-phile(tm)
In the summer the creek is dried up. He could have been hiding in the "natural vegetation" thou.
dave
#109 | |
after a few pops, Cal could well create his own irrigation - I'm sure that wouldn't be the first time
#110 |
| Driver/enclosure to complement Alpair 10.2 FR Pensil in a FAST system? | southernoise | Markaudio | 24 | 7th February 2011 01:04 PM |
| Alpair 12 vs Alpair 10.2 and a little Fostex 166 | germpod | Full Range | 4 | 28th January 2011 03:19 PM |
| PVC Alpair 6 Pensil | guglielmope | Markaudio | 18 | 27th June 2010 07:07 AM |
| Alpair 10 Bass + Alpair 5 - Woodwill Japan | markaudio | Markaudio | 16 | 26th January 2010 11:48 AM |
| Alpair 10 wide bass driver and Alpair 10 Fullrange | _henry_ | Full Range | 71 | 15th March 2009 11:37 AM |
