#51 | |
Bob, I was going to ask him to share his secret tinitus: care to enlighten us
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#52 | |
![]() with fullrange you have to stay with what they do well, and stay away from what they cant do and on subject EQ, its probably a good way to take it to the next level I would use it too and yeah, usually worked better with tube amps if rock music is your main music, use a fullrange with good Xmax and relatively heavy diaphragm, and a super tweeter a FAST design could be the next option passive, and classic 300-500hz xo point now Im in trouble
#53 |
Perhaps a more important question on speaker efficiency is ....
Using year 2010 speaker technology, is there an efficiency range that produces the best sound quality with adequate dynamics and good living room placement? The speakers I favor are between 94 to 98 db/watt efficiency. This range seems to offer the best combination of wide bandwidth, flat SPL/frequency, low phase spread, acceptable box size, and easy crossover design. PERSONALLY, I would not own the 105 db/watt Klipschorns, but really enjoy the sound of 98db/watt JBL DD6600 and 93db/watt JBL K2 S9900. I own a couple Tang Band W8-1808 8" full range speakers with 94db/watt efficiency in an MLTL and like the sound and simple equalization. Some of the higher efficiency 8" full range have response curves that seem beyond my talent to equalize, or require complex horns. Is there an efficiency range that produces the best sound quality? |
#54 | |
sorry couldn't resist OK kids, pull up a chair and grab some popcorn, the movie's about to get interesting... all kidding aside, the JBL6600 are a gorgeous piece of industrial art - I'd certainly love to hear a pair
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi Last edited by chrisb; 28th January 2011 at 05:51 AM. |
#55 |
Excepting bass, I've owned up to ~112 dB/4ft eff. (freaking huge by most folk's standards) and in some ways wanted more, but my (merely huge) current ~104 dB is already too high for its signal chain's noise floor for best total SQ, so this to me is the limiting factor for 'best' eff..
If we accept cinema reference for peak/avg. and 8 W at vanishingly low distortion, then in an average room, ~96 dB/m should suffice. Some symphonic CDs have up +30 dB (clipped) transients though, so to keep from clipping the amp we need ~106 dB/m eff.. This is moot though if the signal chain and speaker's HF isn't good out to 25-30 kHz to cover its leading edge, so when talking 'best', this ideally needs to be part of the equation. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#56 | |
).So just an update, I've been doing lots of reading based on threads and articles suggested here. At the moment I'm leaning toward some trials with line source and waveguides using v cheap drivers, then using that as a springboard to deciding between them. But first to finish design work on the amp itself... |
#57 |
GM, what are your current speakers like? I read earlier that they have dual HF woofers but would love to know any details you're willing to share!
#58 |
>>> They have full range 12 inch drivers, and BOY are they efficient.
>>> JBL DD6600... >>> and in some ways wanted more... Yes, more, more, MORE! I've been listening to 12" wide range drivers lately and love them warts and all because they present music with a bigger, more lifelike sound than any of the smaller drivers i've been using. The smaller drivers do some things better but overall, i really enjoy larger drivers... and yes, i want more! I have those TB 1808 and think they are great. Next to the Eminence 12lta you can barely hear them. Sure the TBs are sweeter sounding and portray some of the more delicate parts of the performance but they don't produce as realistic a performance as the larger drivers. I have even smaller Fostex 127e, 168s, 165k and several other nice full range drivers... but they seem to sound like their size suggests... smaller drivers sound smaller to me. Larger drivers excite the air. Music FEELS more real. The room bristles with excitement. When Shelby Lynne's voice filled my room last night i was in heaven. After a long day of shoveling it was a great way to unwind. Phantom of the Opera rumbled, startled and felt more real in my listening than it ever has... I bet that Jensen 12" sounds great. If you have the room, go with bigger drivers! That JBL is gorgeous! |
#59 | |
GM
#60 |
Gadzooks, GM, 20 cubic feet! 16Hz?!
Sounds pretty sweet. If that's your make-do system, I can't imagine what your ultimate system would be. |
| What is the highest ohm speaker? | nige838 | Full Range | 8 | 21st October 2010 09:15 AM |
| The highest quality ouput ? | onis_uk | PC Based | 23 | 15th April 2010 11:38 AM |
| Worlds expensivest highest Efficiency '15 woofer: Goto SG38WN Series up to 110db/W/m | tiefbassuebertr | Multi-Way | 14 | 29th March 2010 01:50 PM |
| highest Sensitivity subs | Amit_112dB | Subwoofers | 14 | 30th July 2007 01:59 PM |
| Highest Quality 2-way | amirmk | Multi-Way | 52 | 23rd August 2005 10:01 PM |
