I just saw this fantastic new driver (fantastic for $12.50 anyway) and designed this rear loaded horn for it. It will kick out some serious bass all the way down to 30Hz, and while not exactly small it is easy to build. Here is the link to the driver. http://www.parts-express.com/pe/show...r=292-430&FTR= and here is a link to my sketchup model http://sketchup.google.com/3dwarehou...ec75ad1a6d21e9
PASSIONN Last edited by brsanko; 14th January 2011 at 07:15 PM. Reason: Added link |
#2 |
Looks similar to the nelson pass cab for the B20. I have this driver and have been listening to it in a small sealed box... tho i've yet to critically listen to it. But it does play music and is a great value for the amount of sound it puts out from top to bottom.
#3 |
I guess I didn't even know Nelson Pass designed speakers. I also tried modeling this driver in a ported enclosure and the horn plays much louder. Didn't try a sealed enclosure but then I've never really liked them. I guess what I'm most curious about is the mid and high frequencies of this driver as I haven't ordered any yet (I don't even have the $25 for a pair at the moment.)
PASSIONN |
#4 |
Many bought the Pioneer B20 (the driver this GRS is emulating) for $25 each not too long ago. If you can scrounge up the money i think it's a very good value. Don't expect perfection but don't expect it to suck either. I like them just fine and think they will find their fans in time. |
#5 |
Well I think the Pioneers are discontinued, which is why the GRS were introduced. I wish they would come up with a replacement for the 4" pioneer that was discontinued last year, as it seemed to perform on par with the Fostex FE126E in most aplications (in theory I never actually tried the pioneers). I will buy a pair of the GRSs and probably the Pioneers too if I can find them it's just not going to be in the next couple of weeks. I've already experimented with the Fostexes.
PASSIONN |
#6 |
Better yet, clone the 4" RS 40-1197, an inexpensive knock-off of the Foster FE103 that performs better overall and requires less tweaking than the Pioneer. Best would be the '60s era FE103 with vocals to rival some fairly high end drivers. With its cream colored cone and red cloth surround, it was snazzy looking to boot.
Then there were all those lovely Corals........... GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#7 | |
GM
#8 |
Been a while since I heard a pair of '60s vintage 103s. They were really nice little things though from what I remember.
IIRC, 'Zilla's got a pair of the 8in GRS's & is finding them to have a pretty similar character to the B20s. Jeff? Last edited by Scottmoose; 15th January 2011 at 09:20 PM. |
#9 |
Someone should start a sticky thread with nothing but links to inexpensive drivers with great performance, and route all discussion to seperate threads. Just a thought.
PASSIONN |
#10 |
Yep, they were so smooth I was able to use just a cap at ~500 Hz and run them full range to a RS (Motorola) tweeter horn capped off at whatever 2.2 uF worked out to. The bottom end was typically RS's 'el cheapo' 12" guitar driver in what was essentially a semi-aperiodic tower that rocked down to around 40 Hz, plenty for the times.
Good times for DIYers, everything wasn't so @#$% technical/expensive to stand out from the crowd! That speaker today probably wouldn't draw flies at one of the bigger DIY Meets any more than a hot rod 'backyard special' from back then that would 'blow the doors off' anything available to the masses would today at even a local car Meet. GM
| GRS 8FR-8: Pioneer B20 for $12? | BHTX | Full Range | 41 | 4th April 2012 02:17 AM |
| GRS full range driver | Godzilla | Full Range | 5 | 11th January 2011 12:13 PM |
| NP:"Simple Sounds Better" TGY:"Simple Food Better" | Gyuri | The Lounge | 10 | 19th December 2009 09:03 PM |
| Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) | hollowman | Power Supplies | 44 | 7th October 2009 07:01 AM |
| Page generated in 0.09208 seconds (87.32% PHP - 12.68% MySQL) with 11 queries |
