#2 |
I'd be surprised if their using an off the shelf driver. If their going to the expense of modifying the mold to emboss their brand they've likely made a few tweaks to the driver as well.
You can view a cross section view of the speaker here: http://www.meridian-audio.info/publi...[3460].pdf But yes if you take the cone of the W3-317SC and the magnet and basket of the W3-881SJ you get a similar looking driver. Last edited by gooki; 13th January 2011 at 08:37 PM. |
#3 |
Oh yes, i didn't see that but it does say meridian at the sides of the driver faceplate.
I suspect you are very correct that the mods are more than superficial. Perhaps they worked with Tangband to modify the driver to suit. That's if it is indeed based on a Tangband product at all. I don't know anything else that looks quite so similar. I suppose i should also refer to it as "wide" band and not "full" range. Thanks for that pdf by the way. I'm tempted to take this speaker as inspiration for a DIY project. I hadn't seriously considered a wide band driver like that for the high end. I reckon in this case the only way Meridian was able to make the most of such a driver is by using the DSP to counteract those elements that would otherwise be unsatisfactory. Though the FR plots are remarkably flat for the Tangband driver. An interesting speaker for sure. |
#4 | |
Have you got a link to the FR plots? |
#5 |
#6 |
Ahhh, I thought you had the plot for the DSP3200
#7 |
frugal-phile(tm)
From the propaganda sheet, XO should be <300 Hz, so this is one of the 1st commercial FAST systems. Kudo's to Meridian if that is the case.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 |
ultimate desktop system?
#9 |
frugal-phile(tm)
I doubt it. Could be a very good one thou.
dave
#10 |
FOR $6500 it better be
| Best full range driver? | markusA | Full Range | 102 | 6th March 2011 04:05 AM |
| best full range driver | cheerio | Full Range | 21 | 8th August 2010 04:08 PM |
| Shallow full range driver | obe | Full Range | 0 | 23rd May 2010 11:58 AM |
| No-Name full range Driver | ArjenShenzhen | Full Range | 13 | 18th August 2008 12:19 PM |
| Full Range Driver | PassFan | Full Range | 4 | 18th November 2003 03:28 AM |
| Page generated in 0.08339 seconds (88.12% PHP - 11.88% MySQL) with 10 queries |
