I was wondering if anyone knows where I can find some plans for a BR. I've heard mixed things about the fostex recommended specs.
#2 |
Well, the published driver specs. for the En units are supposed to be more accurate than those for the old units. That said, because they are presumably averages, they don't entirely agree, e.g. Vas on the 103 based on the other figures on the sheet should be about 1/2 litre lower than stated.
Anyway, adjusting for that, there are plenty of options. T/S maximally flat is 2.7 litres tuned to 100.6Hz. Keele's alternative alignment = 3.26 litres tuned to 91Hz. And if you have an amplifier with a high output impedance, a Vb = Vas, Fb = Fs alignment should do a decent job. They're not going to have a massive dynamic BW, but for what they are, they should be OK. |
#3 |
Disregard this post, haha.
#4 |
Ah ok, thanks for the info! I have one more question, regarding port area. WinISD recommends a 4in/10cm port, which seems a little large, would a 2in/5cm port be adequate?
#5 |
frugal-phile(tm)
Here is a 1st pass sim based on factory numbers... doesn't go very low in BR.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 |
#7 |
frugal-phile(tm)
A bit droopy for my taste, but you see alot of alignments like this.
dave
#8 |
Droppy as in lack of midbass punch ?
Sand till the end of time |
#9 |
frugal-phile(tm)
It refers to the shape of the roll-off at the bottom. Mid-bass = 40-80 Hz. There is a decided lack.
dave
#10 |
Righto. I too, prefer the cabinet tuning on your 1st sim.
| Small Fostex Bass reflex | audiophile36 | Full Range | 16 | 13th April 2008 09:04 PM |
| Fostex FE207E bass reflex enclosure | Thomas B | Full Range | 9 | 28th January 2008 11:23 PM |
| Recommended Fostex Bass reflex Enclosures | drwho | Full Range | 1 | 29th October 2007 06:28 PM |
| Fostex reccomended bass reflex/horn | Phergus_25 | Full Range | 6 | 15th March 2007 06:08 AM |
| Fostex w/ Bass Reflex? | theseum | Full Range | 21 | 18th April 2006 10:07 AM |
| Page generated in 0.09926 seconds (81.52% PHP - 18.48% MySQL) with 11 queries |
