Old 10th January 2011, 07:24 AM   #1
KnyazHM is offline KnyazHM  Russian Federation
KnyazHM's Avatar
Send a message via ICQ to KnyazHM Send a message via Skype™ to KnyazHM
Question Fostex FE206ES-R vs FE206E or FE208EZ+T90A
Has anyone compared FE206ES-R with FE20E or FE208EZ+T90A? What are they better?
Should I change FE208EZ + T90A at FE206ES-R? Or does not make sense?
Old 11th January 2011, 05:58 PM   #2
thetubeguy1954's Avatar
Send a message via Yahoo to thetubeguy1954
I did a very similar approach. I started with Sachiko cabinets with FE206E drivers. I then replaced the FE206E with FE206ES-R drivers and that was a very signifiicant upgrade sonically. Due to my own stupidity I ruined the FE206ES-R drivers so I replaced them with the very rare ---{250prs world-wide}---FE208ES-R drivers which were another quite significant upgrade over the FE206ES-R sonically.
The only problem was the FE206ES-R are full-range with whizzers and the FE208ES-R are very wide-range without whizzers, so in my Sachikos the FE208ES-R had a freq resp of 80Hz to 10Khz. I put in a pair of large Heil dipoles that crossed in at 8Khz and covered from 8Khz to 25Khz. Now I'm also using a pair of Hawthorne Audio 15" OB dipoles called "Augies" which cross in at 100Hz and cover from approx 25Hz to 100Hz and I've nvr been happier with the results. I can play Led Zepplin at 110dB peaks, that's crystal clear with no sign of strain or distortion!
I believe the FE208EZ+T90A you're thinking about would produce very similar results and would highly suggest going that path and saving yourself the time & effort I went through to get to a very similar design. You can check out my system with the FE206 and FE206ES-R drivers here: Thetubeguy1954's Final Audio System... - My Photo Gallery I hope that helps.
Tom Scata (thetubeguy1954)
Central Florida Audio Society--SETriodes Group--Space Coast Audio Society---Full-range/Wide-range Drivers---Front & Back-Loaded Horns.
Old 11th January 2011, 06:46 PM   #3
I've got both the 206esr and the 208ez (not esr) with the t90a. The 208ez is a much better driver and I consider it one of the best I've heard. (Too bad as the 206esr has the better motor and surround.) Very underated and overlooked, sadly. However, it needs help on top although it is enjoyable as is with some c37 on it with Bud P. enabl. The t90a to my ears is almost unlistenable, like 600 grit sandpaper rubbing together. Do you want to buy mine? Instead buy the t800, it is a lot more expensive but worth every penny. I think I saw a pair on Agon recently. Or if on the cheap, buy a pair of old JBL or Altec compression drivers, remove the rear cover and be amazed at how good it sounds.
Old 12th January 2011, 08:05 AM   #4
KnyazHM's Avatar
Has already bought FE206ES-R. As will arrive I will compare them with 208EZ+T90A
Old 12th January 2011, 08:09 AM   #5
KnyazHM's Avatar
Has tried Omega Mq8lbomega in BLH. Sound beautifully, interestingly. But they for Bass-reflex. These are beautiful and great full-range drivers!
Old 20th January 2011, 04:27 PM   #6
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by thetubeguy1954 View Post
I can play Led Zepplin with no sign of distortion!
why in the world would you want that ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 20th January 2011, 04:31 PM   #7
Scottmoose's Avatar
99.999% of BLHs are bass reflex boxes. They just happen to be quite small and have very large expanding vents.
Are Omega actually selling these units now?
Old 20th January 2011, 04:47 PM   #8
Seeing that you asked, I listen to Jazz most of the time. In fact probably 95% of the time, but having grown up listening to Prog-Rock like Genesis, Yes, Led Zepplin etc. I still sometimes get the urge to put some Prog-Rock on and blast the music! I think hitting 110dB peaks is pretty loud without breaking up, so I happened to mention the Sachiko Reference I's capabilities for those who claim full-range/wide-range drivers always break up at loud listening levels!
Thetubeguy1954 (Tom Scata)
Old 21st January 2011, 03:27 AM   #9
KnyazHM's Avatar
I have compared Fostex FE206E, FE208EZ, Sonido SWR 200 Alnico and Omega Mq8lbomega.
Mq8lbomega - The most musical full-range drivers. They are simply magnificent! Now I wish to buy finished speakers.
Old 21st January 2011, 09:48 AM   #10
Scottmoose's Avatar
Whatever musical means. My question stands though -are Omega selling these drive units separately now?
Fostex FT96H with FE208EZ KnyazHM Full Range 0 6th January 2011 07:10 PM
FS: 2 super tweeters Fostex T90A + 2 attenuators Fostex AT50H merlin el mago Swap Meet 7 29th October 2010 09:14 PM
WTB: Fostex FE208EZ Sigma SMEagol Swap Meet 0 12th August 2009 02:50 AM
which 8' fostex ? ff225k, fe206e, fe208ES, fe206ES-R ? Lagroute Full Range 10 28th April 2006 04:14 PM
Page generated in 0.10756 seconds (79.90% PHP - 20.10% MySQL) with 10 queries
