Old 8th January 2011, 02:27 PM   #1
coldcathode's Avatar
Default BD Pipes Design ???
If one wanted to take the basic Fostex/Rat Shack design BD Pipe and use a completely different driver (Audax HT130K0) how would one go about calculating the dims and port sizes?
Designing a pipe to meet the 44hz Fs is easy buy how to account for the "bi-pole" design ? Use the same Fs? wont the greater (2X) Vas effect it?
Help??!!
Old 8th January 2011, 05:01 PM   #2
frugal-phile(tm)
planet10's Avatar
BD-pipes are a mass loaded TQWT. Usually you use the MArtin King software to model them. With 2 drivers you need 2x the cross-section.
The BD-Pipe is a guess & by golly design, with proper modeling something better should be achievable.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th January 2011, 09:02 PM   #3
so I get the 2X cross section criteria, but as far as the "bi-pole" configuration at what point along the length is the second driver?
Old 9th January 2011, 12:18 AM   #4
frugal-phile(tm)
planet10's Avatar
The line is optimized for a single driver (with either half the xSection or a composite driver with approprite specs) then the average position of the drivers is the optimum. In a push-push bipole that means at the optimum with drivers on opposite sides.
dave
Alpair drivers in some BD pipes sapdog Full Range 1 14th April 2010 09:24 PM
BD Pipes driver questions Carlp Full Range 20 10th March 2010 03:41 PM
bd pipes port material? porkchop61 Full Range 30 27th May 2009 07:50 PM
Page generated in 0.07103 seconds (83.80% PHP - 16.20% MySQL) with 10 queries
