Old 6th January 2011, 07:16 PM   #1
chirs is offline chirs  United States
Default Newbie looking for first project advice
Hi all,
I've been lurking the forums here for a while and have really appreciated this little corner of the internet!
I have a friend who is a wood worker and is offering to build me some nice speaker cabinets...I am having my Fisher 400 restored and am looking to build something that follows this criteria:
1. Simple in design/philosophy
2. A floorstanding design that has drivers/grill placed at the top of the tower, so as to avoid my cat using the speaker as a scratching post. (I may be persuaded to go bookshelf, but that forces me to use stands...which I think are ugly)
3. Electronics either easy enough for a complete newbie to do (BSC I would probably feel comfortable with). If I go two way for some reason I would want crossovers as kit.
4. Cost under $350 for drivers / electronics
5. I listen to mostly jazz, krautrock, soul and classical
A JX92 MLT like this seem right up my alley. Not sure if it's a good fit with my amp (too much midrange?).
Given that woodwork is not a cost issue, where is the performance/cost ratio benefit me more? Using my full budget on something like the Jordans or buying a 2way + crossover kit?
thx!
Old 6th January 2011, 07:28 PM   #2
49 - for the 16th time
c2cthomas's Avatar
P10 has some nice designs for several different full range drivers - esp. the Fostex and Mark Audio drivers.
As far as distress concerning the cat using the speakers as a scratching post - well I have a way that "goes with the flow" in those regards - see photo - called "cat scratch speakers".
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod
Old 6th January 2011, 07:50 PM   #3
Brilliant!
Old 6th January 2011, 08:05 PM   #4
vinylkid58's Avatar
Take a look at the Pensil 10.2:
http://homepage.mac.com/tlinespeaker...aps-211010.pdf
jeff
Old 6th January 2011, 08:11 PM   #5
jimbro is offline jimbro  United States
It always helps to give dimensions of your room, where you will be sitting with respect to the speakers, and how far from the back and side walls the speakers can be.
Old 6th January 2011, 08:12 PM   #6
So these Fostex full range designs from Planet 10 don't need any electronics?
Old 6th January 2011, 08:16 PM   #7
c2cthomas's Avatar
Brilliant!
Yeah - buuuuuuut that is an omnidirectional design and drives the constant directivity school of thought crowd absolutely outta their freak'n gords!!!
Dat's ok - I like the omni sound - but I would like to build up a pair of Econo-Wave speakers AK Design Collaborative - Econo-Waveguide Speaker - AudioKarma.org Home Audio Stereo Discussion Forums and a set of OB's using some Mark Audio A10's I have my hands on.
I would also like to explore Mars, discover a way to break the speed of light barrier, win the lottery (THE lottery), and be able to keep up with a 24 Y/O mistress (and not get caught) etc.
1st on the list of things to do - check my medications - I think I might be off a couple of doses.
Old 6th January 2011, 08:18 PM   #8
c2cthomas's Avatar
Most full range speakers do not need crossovers etc. Some people like to fool around with transformers and sub-woofers tho. Don't go there - at least not yet.
Old 6th January 2011, 08:24 PM   #9
chrisb is offline chrisb  Canada
well amps to power them of course, but certainly no XO for full-range designs, and lots of folks quite happy without passive or line level BSC/ Zobels / contour EQ etc.
Even if you add helper woofers, the most filtering you'd probably need on the wide-band driver portion would be high pass to allow for more dynamics and power handling over their operating range - and that can easily be incorporated by adding / adjusting values of input or coupling caps on most amplifiers.
As for low pass filtering to add tweeters, my personal attitude is that if the wide band driver has sufficient "issues" with tonal balance to require compensation more than achieved by a simple first order on the added "helper" tweeter, then it's the wrong wide-band driver for the job
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 6th January 2011, 08:26 PM   #10
I haven't decided which room to put them in yet. Trying to figure out where to build record shelves...
Either way, both potential rooms mare 15x15ft. One room is minimally furnished at is very resonant. I'm assuming that's a bad thing.
Most likely it will be in the living room (16x15ft...lots of "stuff" in there). Speakers 10-12 ft apart, with the listening couch about 10ft out from the center.
Advice (Newbie) -=PLuKE=- Multi-Way 1 11th August 2006 04:03 PM
advice about project wanted (newbie) kmj Tubes / Valves 12 19th January 2006 01:17 PM
Newbie Needing Project Design Advice cwoodall Everything Else 1 23rd August 2005 04:27 AM
Newbie project advice BHolmes Chip Amps 9 18th July 2005 09:05 PM
Advice for a newbie Kofi Annan Solid State 11 30th January 2004 12:50 AM
Page generated in 0.11117 seconds (82.62% PHP - 17.38% MySQL) with 11 queries
