I'm working on a CHR-Ken for a first build. The plans suggest cutting the bevel on the front after the box is complete. Could someone explain how one should go about this? I have a circular saw, a router and nine thumbs. I had been planning on using a 45 degree router bit on each panel before gluing. Is there some reason that wouldn't work or would be more difficult?
Thanks. |
#2 |
that would work just fine jonedd if you don't have a tablesaw . then just sand everything flush after a careful glue up .
you'll need to clamp each side to another board or straight edge for the router bearing to ride on . cheers , Woody |
#3 |
Your proposed router approach will work, as Woody has indicated, but, having built several of these enclosures myself, the end result will benefit from building as per plans and running the whole shebang through a (friends?!) tablesaw.
Good Luck with your project.The above boxes, with the MA chr-70's are a killer speaker! Best, DonIMG_1103.jpg I should add that Chrisby has probably built as many of these as anybody, perhaps he's got a trick or two up his voluminous sleeves! Last edited by doorman; 5th January 2011 at 08:25 PM. |
#4 |
Thanks for the suggestions. I guess I'll try with the router this time and see how clean I can make it look with some sanding.
Chances are I'll have to start over again anyway--it took me four baffles before I could recess the front and bevel the back of the driver hole without breaking anything. I covet a good table saw, but I want to get at least one project completed first (I'd borrow, but knowing me it could be months). |
#5 | |
Don - a few dozen pairs, yes; cut the bevels in several steps with the blade tilted away from the rip fence - one kickback offcut can ruin your weekend, and keep yer fingers out of the way actually, I try to remember to cut the bevels before adding the felt damping pads and setting the back panel in place - it helps keep sawdust out of the boxes, which for these size drivers are rather tricky to access once fully buttoned up
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
| CHR-Ken? | albireo13 | Full Range | 10 | 6th November 2010 06:07 PM |
| CHR-70 for a first time build | gideon | Markaudio | 4 | 26th October 2010 03:22 AM |
| Lotus BVR/CHR-70 - Question about suitability | BL21DE3 | Full Range | 37 | 3rd January 2010 12:55 AM |
| My first build! MarkAudio CHR-70 in da house | tresch | Full Range | 38 | 31st August 2009 10:07 PM |
| Ken Ealey Mods???? | johndi | Pass Labs | 13 | 11th June 2008 06:50 AM |
| Page generated in 0.09100 seconds (73.72% PHP - 26.28% MySQL) with 11 queries |
