Old 4th January 2011, 03:30 PM   #1
rock12 is offline rock12  United States
Default cabinet material
I have a lot of hardwood around what are the pro's and con's of hardwood to plywood?
Old 4th January 2011, 03:48 PM   #2
Speakerholic
Cal Weldon's Avatar
Don't for get to use search. Hard wood often splits if not dried in a controlled environment for 50 years. More stress than average furniture.
density of cabinet material
Cabinet w/Hardwood front baffle
Hardwood plywood for speakers?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 4th January 2011, 04:13 PM   #3
chrisb is offline chrisb  Canada
Without getting into the polemics again (what, politics on an enthusiasts' forum? ), let's not forget that there are some fine examples of solid hardwood furniture / musical instruments several times our own ages that are surviving just fine, (I'd say a 9 ft concert grand piano is subject to at least as much stress as most domestic loudspeaker systems), while a 2 yr old PB/ MDF / or plywood cabinet can experience a variety of failure modes (i.e. integrity / finish etc.)
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 20th March 2011, 05:31 AM   #4
Mikelo is offline Mikelo  Antarctica
True, but what about the issue that a violin or piano is meant to resonate while
a speaker shouldn't?
I'm thinking about a solid 1.5 inch/38mm maple baffle.
Old 20th March 2011, 05:55 AM   #5
try 29 -32mm
Old 20th March 2011, 06:16 AM   #6
Originally Posted by chrisb View Post
<snip> let's not forget that there are some fine examples of solid hardwood furniture / musical instruments several times our own ages that are surviving just fine, ...
I suspect Cal's point is still at work here. My musical instrument, made out of a solid block of big leaf figured maple, was treated by the manufacturer for 15 years after they purchased the cut and dried stock. It needed to be oiled occasionally in the first 10 years and less frequently as time goes on. Yes, it will last forever. I nearly purchased a 1929 instrument before settling on my horn, made in 1992. However, careful treatment before and after working is probably needed for anything you expect to be air tight.
Old 20th March 2011, 08:00 AM   #7
Sound with Style
THORNSPAWN's Avatar
These are solid hardwood, kiln dried Victorian Ash, no special treatment, they have been sitting next to a window for over a year with no problems yet. All panels are 32mm thick though with all joins mitered and expanding polyurethane glue.
Using anything thinner would be asking for trouble.
Australian Frugel horns and flat pack kits now available at http://www.soundwithstyle.com.au
Old 20th March 2011, 09:14 AM   #8
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
The main problem with hardwood cab's are cross grain joints, as solid wood expands/ contracts different along the grain vs across. This might cause problems and splitting. Solid wood WILL contract and expand with varying humidity, - how much is a matter of size and wood types, among other things. Cabinet and furniture makers have long since devised methods to avoid the problem. For a small cab, this should be a minor problem , if any at all, but for a larger, say 100l +/- , grain orientation is a matter for serious concideration. I've asked myself this question for many years, as it would solve many problems related to finishing, provided one has a little more than basic woodworking skills. One solution to the problem could be to screw front and rear panels, so give some compensation for movement. Vibrations can be controlled by bracing and damping
BTW- nice speakers, Thorn, - proves exactly my point for finishing.....
( The problem in my corner of the world, is that all the small scale wood suppliers, small workshops etc are all gone, and the only resource available locally, is construction grade pine.....even veneers are almost impossible to get in DIY quantities.... Sigh. )
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
density of cabinet material andy1971 Construction Tips 10 2nd January 2010 12:50 PM
Corian for cabinet material nbcaudio Full Range 7 9th March 2005 01:02 PM
Cabinet Material??? FrankRoss Multi-Way 12 15th February 2004 03:22 AM
Speaker cabinet material byteboy Multi-Way 16 12th June 2003 07:25 PM
speaker cabinet material dsrviola Multi-Way 4 1st January 2003 06:28 PM
Page generated in 0.11112 seconds (80.14% PHP - 19.86% MySQL) with 10 queries
