I have been looking at the build plans for the Frugal Horn and the designer states early on the cabinet could be used for a wide range of drivers with minimal modifications (my interpretation). Specifically he refers to the CC. I was wondering if anyone has optimized this plan for use with the 127e and if so would they share that information with me. I understand there are many good plans for the 127e, that said....I still want to build this cabinet. If needed I will buy the 126e to go in it but I thought I would try to start with what I have on hand.
If someone hasn't specifically redesigned this plan for the 127e then maybe someone could look at the TSP of the 127e and steer me in the right direction. My first experience with a rear loaded horn design was with the Chili Changs. I had a pair of 167e drivers and had the cabinet built exactly as specified. It sounded wonderful. I later picked up a pair of 166e drivers for a bargain and attempted to use them in the Chilis....there was a considerable difference in the bottom end response, it seemed a bit more muddy and boomy at times....I was quite shocked by the difference in the two drivers as they on the surface seem so identical. So, I do believe these are designed for the drivers they are designed for. I fear if I try to model these for my 127e I might end up with something that works for neither driver. Good advice solicited now.... Jeff |
#2 |
frugal-phile(tm)
Josh in Atlanta built at least one pair with FE127 -- it was suggested he start with a larger Air cavity (CC) but just built it with the small one. He was happy.
I would suggest looking at FH Mk3 which should provide a better load for FE127 dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
jeff- since you asked for it, you can guess which 3 or 4 designs I'd recommend for the FE127 - and I think your intuition about one enclosure modified for both 6 & 7 series without compromising performance of either is probably right
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#4 |
Well now you have to tell which 3 or 4... you can't leave us hanging like that.
#5 | |
Fonkens; prime/ Milli / floorstander (cumulatively dozens of pairs of the various designs, the Prime still my personal favorites - within their limitations an absolutely enchanting little speaker, but agreeably not for everyone ) Meet the Fonkens Brynn (half size Chang BVR) http://homepage.mac.com/tlinespeaker...map-021107.pdf Mileva ![]() Harvey: http://homepage.mac.com/tlinespeaker...ey-1v1-map.pdf PAWO Tom Zurowski PAWO Rear Loaded, Wide Baffle, Side Venting FR125S Horn DIYaudio reference diyAudio Full Range Reference Project at the risk of starting another flame war, this is a design that we also built a variation of for CSS FR/WR125 in both MDF and BB ply - which me conclusively settled the question also would love to try in appropriately tuned micro-tower, and inverted BIB, but the demise of the FE127 and pending the release of new FF series has our attention presently focused elsewhere In BLH* for drivers of this size, I prefer the FE126 - certainly not completely neutral, but too much fun to ignore * the name of the website below and links therein should give a good hint
| Frugal Horn and Audio Nirvana | Pemo | Full Range | 2 | 21st November 2010 05:43 PM |
| Frugal horn build | djdaveysprocket | Full Range | 16 | 3rd May 2010 06:36 PM |
| fe 127 & frugal-horn | mcr483 | Full Range | 2 | 26th December 2009 08:25 PM |
| Single Driver Horn Base Port from Frugal Horn | EmergencyDpt | Swap Meet | 0 | 26th October 2008 01:24 AM |
| mikasa/spawn family/frugal horn | lornie | Full Range | 11 | 15th June 2008 10:24 PM |
| Page generated in 0.09606 seconds (77.58% PHP - 22.42% MySQL) with 10 queries |
