..etc looked at FR88/89, Daytons, TBs etc and some opinions are that most seem to need some kind of help, either breakup or other issues
Just thought to compile a proper list would be beneficial to those looking to choose because to me a big point of the 'full range' driver is simplicity and/or lack of components in the signal path etc. Seems like the Alpair 6 is smooth so I will put forward these two Alpair 6 Jordan JXR6 Last edited by Bill poster; 25th December 2010 at 06:33 PM. |
#3 |
frugal-phile(tm)
Alpair6 can be used sans woofer help, JX6 needs helper woofer for sure.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
planet 10 I'm sorry, should have made the thread starter clearer- ie its purely about top end issues, whether they need bass support etc was not my criteria.
Its just odd that so many small metal wide bandwidth drivers are being released but virtually all have issues at the top end in some way and benefit from a circuit or a tweeter. Last edited by Bill poster; 25th December 2010 at 09:26 PM. |
#5 |
Alpair 7eN, mounted in a correctly sized resistance loaded box, does not "need" a sub woofer. However, correctly mated to something as fast and with as much textural ability as the 7eN has, provides a startlingly good system. The only portion missing is the "weight" of upper bass, from 100Hz to 400 Hz. This points to having a larger diameter Mark Audio driver if that FR is important to you.
The Alapair 7eN has no issues anywhere and flat to 30K does indicate it's ability to resolve inner information within tones and transients. Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa Last edited by BudP; 25th December 2010 at 09:31 PM. |
#6 |
Whether a circuit is required is not really a function of the driver, but of the whole driver / cab geometry / boundaries / room / listening position.
If you want to avoid a circuit, just use two drivers |
#7 |
Its purely about how a driver measures.. sans room effect, little piece of foam or jar of water in front of cone etc.
#8 |
here is an example how foam affects FR.
block of foam placed in front of a Neo-8 driver. neo8-waveguide.gif |
#9 | |
Davy Jones |
#10 |
I don't know what kind of foam it is. It is pretty dense and soft.
It's from discount hardware store. Here are some more pictures Twisterspeakers DIY loudspeaker projects: Neo8 planar transducer in a waveguide |
| Vintage FR BR ...adding a tweeter? | waam68 | Full Range | 0 | 24th December 2008 11:39 AM |
| Measuring tweeter FR without a highpass filter | owdi | Multi-Way | 3 | 14th March 2007 05:40 AM |
| Senon FR + Tweeter in OB | inrank | Full Range | 2 | 1st February 2007 11:09 PM |
| WTB: 269-469 ("1$ Parts Express") drivers, or other really cheap FR drivers. | Spasticteapot | Swap Meet | 1 | 5th November 2006 03:31 PM |
| 'phase-plugs and FR', metal dust | Timbo in Oz | Full Range | 1 | 6th July 2005 01:50 AM |
| Page generated in 0.11790 seconds (72.72% PHP - 27.28% MySQL) with 11 queries |
