Tang Band W3-1797 S flat diaphram 'full range'
Old 24th December 2010, 11:05 AM   #1
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Default Tang Band W3-1797 S flat diaphram 'full range'
Anyone used these? They are 3" and have a flat aluminium diaphram (and a horrible grill). It takes 50 w max but has just 1 mm xmax (seems a bit odd)
The plot shows a very gentle rise above 10khz which is ideal.
Here is an interesting design (japanese?) using the unit
V‚‚AUDIO‚̐ŠE‚‘n‚
Here it is on parts express
Tang Band W3-1797S 3" Neodymium Midrange Driver | Parts-Express.com
would love to hear more about them if anyone has experience- they get a good review in a speaker design costing $12,000 here http://www.6moons.com/audioreviews/boenicke2/sls.html
Old 24th December 2010, 11:52 AM   #2
hm is offline hm  Europe
hm's Avatar
Hello,
the grill is a part of the function.
merry Xmax
http://www.hm-moreart.de
Old 24th December 2010, 11:55 AM   #3
Originally Posted by hm View Post
Hello,
merry Xmax
lol whats its function? apart from prodding fingers
Old 24th December 2010, 12:32 PM   #4
chris661 is offline chris661  United Kingdom
chris661's Avatar
As a designated midrange driver, the 1mm Xmax should be plenty, as it shouldn't see any low frequencies. One of the reviewers on Parts Express didn't seem to know that.
The grille may help to control dispersion patterns (thus shaping the power response), but I'm not sure and could be wrong... I've heard of similar ideas being used before, that's all.
Chris
My work: www.grimshawaudio.com
Old 24th December 2010, 01:38 PM   #5
5th element is offline 5th element  United Kingdom
5th element's Avatar
Zaph reviewed its larger brother favourably, all except for a resonance that, depending on how picky you are greatly limits its use as a full range.
If this is a result of the flat cone, then the little version probably has something similar too, although most likely at a higher frequency.
You can find his review on his blog.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 24th December 2010, 01:45 PM   #6
the response looks good - I don't think it suffers the same issue as the large version. .a little wobbly but no break up per se where it matters
read that review too.. sounded like a prize plum
regarding where to x/o, would 180-200 hz be ok?
Old 24th December 2010, 02:32 PM   #7
chris661's Avatar
That crossover would probably be okay, so long as it's a steep enough slope. First order would likely not give enough power handling for higher volume listening.
Old 24th December 2010, 02:38 PM   #8
If you look on the TB website both the W3 and the W4 have good looking frequency responses. The W4 has a slight impedance wobble at 2k which coincides with Zaph's measurements. The W3 has a wobble at about 3.2k which could indicate a similar resonance and HD peak issue similar to the W4.
TBs own graphs tend to be skewed towards making sales rather then absolute honesty.
4th order acoustic @ 200hz shouldn't be a problem, but if it has a similar HD peak you'd want to cross this driver steeply at about 1500hz to a capable tweeter. I'd buy with caution and be prepared to measure the thing before using it. If they were somewhat cheaper I'd buy one and measure it myself.
Old 24th December 2010, 06:33 PM   #9
hm's Avatar
Default Bill
lol no knowledge?
it is a lens.
look the dispersion,
here the W4
both ideal for my Mini Posaune and Kornett.
Bass down 34 Hz, bipol double horn.
Old 26th December 2010, 08:52 PM   #10
DYNABLASTERTUNERS is offline DYNABLASTERTUNERS  Serbia
DYNABLASTERTUNERS's Avatar
here in 10 000$ Loudspeakers and no aditional Tweet
6moons audio reviews: Boenicke Audio SLS
Tang Band W3-1797 S flat diaphram 'full range'Hide this!Advertise here!
Help with TB w3-1053sc 2500hd Full Range 4 29th May 2010 03:12 PM
Tb W3-832se e_fortier Full Range 1 20th August 2008 07:52 AM
Tb W3-593sf sdclc126 Multi-Way 4 19th September 2007 03:14 PM
Tb W3-871s PeaveyBassist Multi-Way 4 14th January 2005 08:14 AM
TB w3-926 cjh Multi-Way 11 24th January 2004 09:51 PM
