Pipe open at one end
Old 19th December 2010, 06:10 PM   #1
Mosquito is offline Mosquito  Argentina
Mosquito's Avatar
Default Pipe open at one end
Hi, I'm working at the idea of a speaker that uses a low compliance, high Qts driver ( fs 100Hz Qts 1) in a constant area column, of around 1m high, say 400mm wide 200mm depth, open at the bottom (the whole 400X200 mm surface), against the floor.
Would this produce a reinforcement at say 70/80Hz, and Does it make a difference (the position along the line) of driver's center, to the closed end? Asuming adecuate stuffing , of course.
I still do not own the MJK soft yet, so I'm not able to simulate the behaviour of this, so only a gross guessing..
J
"It is less serious than if worst"
Old 19th December 2010, 06:46 PM   #2
DualTriode is offline DualTriode  United States
J
Hello,
Sounds like a transmission line to me!
The length of the tube plus the stuffing determines the phase at the far end of the tube.
The stuffing working with the Qts of the driver determines the damping of the speaker (goal 0.71 total Q)
Have at it!
This is the stuff that keeps people up at night.
Saturday the stuffing goes in the turkey.
DT
All just for fun!
Old 19th December 2010, 07:50 PM   #3
Mosquito's Avatar
We here save the Turks and eat steaks
Maybe I need to clarify a bit. I do not ask "what type of driver will do best"
For a number of reasons the driver is as it is, I need to optimize the enclosure for this particular driver. And yes, it falls in a sort of not folded, very short, transmission line.. a rectangular tube bah..
Old 19th December 2010, 08:29 PM   #4
Hello,
When I said “have at it” my reference was to do a little trial and error. Your enclosure is likely a little long an thin (having TL properties) it will also have internal resonance, sound bouncing around like you singing in the shower or one note bass that is where the stuffing comes in.
To get your creation to reinforce around 70 to 80 Hz here is my trial and error recommendation; close off the open end with plywood and drill 50 mm holes in it until it sounds good to you! When you have drilled too many holes backup one.
Steak does sound good!
DT
All just for fun!
Old 19th December 2010, 08:49 PM   #5
Mosquito's Avatar
Thanks!, Good advice.
Now I`ve to get out to buy some bottles for the 24 nite
Cheers
J
Old 19th December 2010, 09:39 PM   #6
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi, I'm working at the idea of a speaker that uses a low compliance, high Qts driver ( fs 100Hz Qts 1) in a constant area column, of around 1m high, say 400mm wide 200mm depth, open at the bottom (the whole 400X200 mm surface), against the floor...Would this produce a reinforcement at say 70/80Hz,.. so only a gross guessing..
FYI,All just for fun!
b
Old 19th December 2010, 09:57 PM   #7
Mosquito's Avatar
sacre bleu! many thanks bjorno! It's pretty much like I envisioned trough my third eye!
Old 19th December 2010, 10:31 PM   #8
Hello,
Fun indeed!
Do you know the woofer name brand model or TS parameters for b to plug into the software, that could make it “real” fun?
DT
All just for fun!
Old 19th December 2010, 10:46 PM   #9
Mosquito's Avatar
Yes, I do.
http://profesional.beyma.com/pdf/12GA50E.pdf
Old 19th December 2010, 11:47 PM   #10
FYI:
b
Pipe open at one endHide this!Advertise here!
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 4th July 2010 12:15 AM
RAW Acoustic Open house end of the year sale DEC 1 ? DIY get together RAW Everything Else 10 30th November 2007 11:29 PM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 08:33 AM
El-Pipe-O (El-Pipe-Mino) ??? JDeV Multi-Way 21 26th October 2005 10:00 AM
Open end position in a TL teodorom Multi-Way 4 13th May 2004 12:33 AM
Copyright ©1999-2017 diyAudio
