Pipe open at one end
Old 19th December 2010, 10:53 PM   #11
Mosquito is offline Mosquito  Argentina
Mosquito's Avatar
YouTube - Frankie Valli-Stay just a little bit longer
"It is less serious than if worst"
Old 21st December 2010, 10:36 AM   #12
Mosquito's Avatar
Probably 1.20 /1.25 M, and yet to be found, the best driver position along the line..
Old 23rd December 2010, 12:58 AM   #13
Mosquito's Avatar
This is a rough sketch of the speaker we are talking about
Following the MJK tables, and the simulation results from bjorno I drawed a line a bit longer.
1.25m minus the boundary end correction is 1.15m
Driver SD is 530cm2, fs 100, Qts 1
The suggested offset is 0.349. but I'm Not sure if it means 1.15 X 0.349 as in my drawing..
Any suggestion is welcome
Cheers
J
Old 23rd December 2010, 01:59 AM   #14
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
I simulated your design:
b
Old 23rd December 2010, 09:51 AM   #15
Mosquito's Avatar
Thanks bjorno this is almost in the ball park of that I was looking for. Now I 'm trying to learn how to use the worksheets, in order to push the Lf limit some Hz down. I think that f3 around 75/80 Hz plus a soft HP slope will be Ok. The intended amplification are small tube units (SE) <5W, with moderate to low DF.
Pipe open at one endHide this!Advertise here!
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
RAW Acoustic Open house end of the year sale DEC 1 ? DIY get together RAW Everything Else 10 30th November 2007 10:29 PM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
El-Pipe-O (El-Pipe-Mino) ??? JDeV Multi-Way 21 26th October 2005 09:00 AM
Open end position in a TL teodorom Multi-Way 4 12th May 2004 11:33 PM
Copyright ©1999-2017 diyAudio
