pairing up f120a's with the f200a's?
Old 14th December 2010, 03:28 PM   #1
bluewater is offline bluewater  United States
Default pairing up f120a's with the f200a's?
Well this would be quite the investment but I already own the f120a ENable off of Ebay a year or 2 ago. They sound wonderful. It took about 2 months to really hear them sing! There in some Fonkensteens that I built. Thank you Planet10! I did a rough build out of some funiture wood that I had laying around. So I plan on rebuilding them from Baltic Birch. These give an amazing amount of bass for such little speakers and I think once it build to specs that they will give even more since the ports are larger than 9.5mm.
What I was wondering is if I paired them up with f200a's (ENable) in another set of Fonkensteens if this would take care of the bottom end and most importantly keep the imaging that I love about these f120s and how they seem to disappear. Would getting an active crossover to tweek it out make sense? If so I've heard Behringer is a good brand but have no clue which one.
Happy Holidays
Old 14th December 2010, 05:55 PM   #2
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
It seems a waste to use a set of F200As to fill in the bottom (below 80-120 Hz) of the F120. You can get much less expensive mid-basses that will do the job better. My gotos are CSS, but you may want to consider the Fostex bass drivers which are very good, and closer in detail to the F120A. For the price of a pair of F200 you could have 4 of the 8" FW208, get more, lower bass, and be able to run them push-push. These should be run active. Getting at least a bit of HP on the F120A should do good things for the mids.
Really glad to see someone is appreciating those F120AeN
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th December 2010, 09:30 PM   #3
Hi Dave! Sorry for my lack of knowing. What does CSS and HP mean? I read a little on the push-push setup and it looks very interesting. One of the forums had a sono tube but I would rather go with sealed encloser most likely unless it sounds that much better with the towering sono tube(looks very cool). Volume specs are the same as for a single woofer for sealed or ported?
Dave I was also wondering if doubling up 1/4" felt would be ok when I rebuild my Fonkensteens, maybe with hot glue or fabric glue.
Eric
Old 16th December 2010, 01:36 AM   #4
frugal-phile(tm)
planet10's Avatar
Only apologize for not asking when you don't know.
CSS = Creative Sound Solutions
HP = High Pass Filter
Doubling up the felt should work. I'd only spot glue it. If you get a chance to score some UltraTouch, we've been spoiled by it.
dave
Old 21st December 2010, 02:43 PM   #5
Very very nice. They look great! Are your subs in a sealed incloser? Are they spec for double the volume? Thanks for the pick.
Old 21st December 2010, 11:22 PM   #6
frugal-phile(tm)
planet10's Avatar
These are a TL stuffed to the point where it might as well be sealed. Volume is 28 litres and fairly heabily damped.
dave
Old 31st January 2011, 05:07 PM   #7
Planet10 how do you think the Apex Jr. Subs as a push-push would do with f120s? The price is right and I've read good things from them. You also have a design on Apex's website. Would this work well with my Fonkensteens or do you think the FW208's would be a better choice.
Old 31st January 2011, 06:47 PM   #8
frugal-phile(tm)
planet10's Avatar
The ApexJr 8s do very well. Modeling doesn't show them going really low, but set next to the wall, or pushed into the corner, i find them very satidfying and match up well with my room gain. They are also much more extended than one would expect for a "subwoofer", a good thing when mating with any FR driver. It is certainly hard to beat them for bang for the buck,
Another candidate is the Silver FLute 8". I haven't personaly used this, but have 5" on hand, and will eventually, This is what Ed S uses in his bass Cube.
The Fostex woofers are very nice, but i'd put them on the far side of the value equation.
dave
Old 31st January 2011, 07:34 PM   #9
frugal-phile(tm)
planet10's Avatar
picture.
pairing up f120a's with the f200a's?Hide this!Advertise here!
pairing 2 16 ohm horns kwpro Multi-Way 0 21st December 2009 08:07 PM
Pair of Fostex F120A's Excellent boudy Swap Meet 5 12th June 2009 04:45 PM
Pairing the Seas Magnum with the E0045 woofer gottagettubes Multi-Way 0 5th October 2008 12:07 AM
vifa pairing rv1890 Multi-Way 2 25th January 2005 07:21 PM
Best 500Hz and down woofer for pairing with ESL? Bas Horneman Planars & Exotics 55 6th August 2003 01:44 PM
Copyright ©1999-2017 diyAudio
