Old 14th December 2010, 11:51 AM   #1
Redge is offline Redge  France
Default Visaton frs8, frs8/m with cyburg ?
Hi all,
very happy to find this forum, so a great forum for diy. Specially for cheap trick.
I read the forum from 3 days, and now I'm lost.
I would like to make a cyburg's needles with visaton, but I don't know what is the best between frs8 4ohm or 8ohm and between frs8 ans frs8/m.
I precise that they will run with a tripath 2024.
Someone can help me please ?
What do you have in your Needle, precisely ?
Best regards and long life to the best audio diy forum I ever seen !
(sorry for my bad english, I tried my best, I'm just a little french guy )
Old 14th December 2010, 04:28 PM   #2
Uncle Meat's Avatar
Hi Redge,
the FRS8M is no good choice for the needles. Xmax is much lower than FRS8..
( thats why SPL is much higher . I have the FRS8M in my car on the dashboard in 0,7l CB, with 12dB active highpass at 240Hz. Almost perfect)
4 or 8Ohms: I would prefer 8Ohms, then you have some options for future projects, e.g. Stella light.
BUT, honestly: the absolute "best buy" is Peerless FR35/8. Why:
40% more Sd, lower Fres, vented magnet, vented suspension, and, most important verall much better sound quality.
All this for just 1€ more than the FRS...
Salutations,
Joe
Old 14th December 2010, 05:13 PM   #3
hm is online now hm  Europe
hm's Avatar
Default redge
Hallo,
i made good experience with the FRS8M
in my Trombone horn,
best imp, bass down 35 Hz, for max.
SPL of~94 dB.
It is a bipol double horn you need two driver each Horn.
http://www.hm-moreart.de
Old 14th December 2010, 05:36 PM   #4
Oh, thank you very much for all informations you gave me !
Very usefull !
For the pearless, I would like to try it, but there's nowhere to get in France (France sucks to get speakers sometimes...)
You tried it in the Needles ?
Best regard Uncle Meat ^^
Old 14th December 2010, 05:46 PM   #5
try to get the peerless at ebay.de
shipping to france will be no problem for most sellers and it is not too expensive
or contact this seller
http://www.spectrumaudio.de/bausatz/needle.html
30 Euros for two, including sonofill, screws, terminals
Old 14th December 2010, 05:55 PM   #6
In this moment, no Peerless on ebay
hm: I know your impressive works, but it is too big, and too "expensive" for me...I ever have the mdf cut, and it will be the needles...but thanks for the advice.
Old 14th December 2010, 06:45 PM   #7
Uncle Meat's Avatar
Hi Redge,
I am building a FAST with FR35/8 ( and Tangband W5/876SA)....
I recently recommended them for somebody in the german HiFi Forum.. And, that guy really loved them - no wonder .
As proposed by Becky, contact spectrumaudio. ( largest selection of FR speakers worldwide ). I am sure, they will not try to make extra profit from shipping costs....
Old 14th December 2010, 07:19 PM   #8
With a TA2024, you want the 4 Ohm version if you can.
Old 14th December 2010, 07:58 PM   #9
chris661's Avatar
Originally Posted by Uncle Meat View Post
Hi Redge,
Joe
Having owned both, I'd have to disagree there. Even the Visaton site gives maximum excursion to be +/- 2.5mm for both drivers.
Apart from that, I found the extra efficiency of the M version to be useful (used as a mid-tweeter from 300Hz).
I'd also strongly recommend the following modifications from stock...
- coat the cone. First, two coats of dilute PVA glue. Allow time to dry properly between each. Next, two layers of varnish. I used waterproof stuff that dried clear and solid.
- Remove the dustcap, install phase plug.
The first modification helped the most, but removing the dust cap helped the sound, too.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 14th December 2010, 08:36 PM   #10
Uncle Meat's Avatar
Hi Chris,
I think, the SPL difference ( if excursion would be the same...) cannot be explained by the stronger magnet.. When you compare it with e.g. 3"Fostex, it becomes obvious that there is something wrong in the Visaton papers ( as per lin. excursion ).....
Well, I already made some mods on my FRS8M car speakers. ( just for the looks ) Maybe try your coating as well...
Regarding Cyburg Needles - What Is A Notch Filter? JimOfOakCreek Full Range 5 27th March 2008 11:44 AM
Visaton FRS8 8ohm or 4ohm to choose? hellmis Full Range 9 2nd July 2007 03:38 AM
Needles with 2 FRS8 drivers TDLofCC Full Range 14 11th September 2006 11:35 AM
HELP! My Cyburg Needle turned into an upside down BIB MuaDibb Full Range 5 22nd March 2006 01:37 PM
Visaton FRS8 line array & W170S Miha Multi-Way 16 3rd November 2004 11:24 PM
Page generated in 0.11171 seconds (79.25% PHP - 20.75% MySQL) with 11 queries
