Old 9th December 2010, 08:24 PM   #1
Bill poster's Avatar
Default Will a Jordan JXR6 work effectively in a tapered TL?
I know this is a spiderless driver specifically designed for a sealed enclosure and I may have asked this question once before (but I cannot find my original question on search)- I am guessing that tapering will offer some back pressure to control cone excursion (how much I don't know) and that the volume of the line would be small if the line is quarter wave.
Would it help if the taper was severe for the first foot, then less severe for the rest of the length?
Old 10th December 2010, 01:41 AM   #2
frugal-phile(tm)
planet10's Avatar
It could be used in a TL if it had an active HP on it, a midTL. I wouldn't use a TL to try to extend the bass.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th December 2010, 04:11 PM   #3
Thanks for answering Dave
I don't want to use it for bass duties, but I wd like to stay passive, x/o will be 1st order at 175 -200 hz . Risky?
Old 10th December 2010, 04:23 PM   #4
frugal-phile(tm)
planet10's Avatar
Probably risky.
dave
Old 10th December 2010, 08:30 PM   #5
Thanks, might give it a try, the worst case is I can swap to something with a spider
Old 11th December 2010, 08:45 PM   #6
hm is online now hm  Europe
hm's Avatar
Default Bill
Hello,
the flute Sat might be a solution down to 120 Hz 6dB,
http://www.hm-moreart.de
Old 12th December 2010, 04:22 PM   #7
Hi Hm, I don't know the flute sat - how does it work? cheers
Old 12th December 2010, 04:55 PM   #8
hm's Avatar
Default Bill poster,
Hello,
look here:
Flute
flutemess
fluteplan
may be goo..Translate helps
Old 12th December 2010, 08:33 PM   #9
Thanks -but would this type of enclosure work with the Jordan?
Old 13th December 2010, 09:16 AM   #10
hm's Avatar
Hello,
would i post it if not?
the advantage is the stroke,
one of the best in such size.
Jordan JxR6 Bill poster Full Range 58 31st December 2010 04:59 PM
Jordan JXR6 HD vs JX92S oceanic30 Multi-Way 1 25th August 2007 08:54 PM
Need suggestions of midbass for Jordan JXR6? Norris Wilson Full Range 47 31st March 2007 04:50 PM
Using in the Jordan JXR6 HD in an MTM David Gatti Multi-Way 3 7th November 2006 07:52 PM
Partner for the Jordan JXR6 jimbo Full Range 23 13th March 2006 11:41 AM
Page generated in 0.10025 seconds (77.45% PHP - 22.55% MySQL) with 11 queries
