Old 9th December 2010, 03:47 PM   #1
Default Tang Band W6-1611 in BIBs
Hi. Ive had my W5-1611s for some time now, breakin them in in cardboard boxes. This weekend I got to some work done in the hobby shop we have in my apartment building. Baffle + back is cut to size, holes routed and today I hope to find some time to work on the sides panels and internal baffle
Im between jobs at the moment so budget only permits me to make do with scrap wood. The baffle and back will be in 19mm hardwood and the sides in 16mm low density MDF. For the internal baffle Im gonna use 30mm medium grade foam. The idea is that it will dampen some of the upper bass
Heres some pix of the project:
- Cardboard box break in
- Dry runs for the routing
Old 9th December 2010, 03:52 PM   #2
Forgot --> Dimension for the BIBs 210x340x2030mm
And heres two more pix:
- Rounded edge behind speaker
- The baffle with speaker
Old 9th December 2010, 08:14 PM   #3
Godzilla's Avatar
Oooohhhh, that's going to be good!
Zilla
Old 10th December 2010, 07:51 AM   #4
Zilla
Fingers crossed
Old 15th December 2010, 09:19 PM   #5
Its big...
Old 15th December 2010, 10:09 PM   #6
Thumbs up Keep at it!
Bigger is Better! Looking good!
Old 21st December 2010, 06:19 PM   #7
After a few failed attempts at glueing and clamping I decided to build a jig for the internal baffle. Worked like a charm
Regards /Bo
Old 21st December 2010, 06:23 PM   #8
thanks
Old 26th December 2010, 08:34 PM   #9
Holy mother of pearl. These things are as resonant as hollering banshees in heat. Wrapping my knuckles on the sides is... interesting... The upper open part is particularly prone to sing the one note song. Im gonna have to try some serious bracing
Regards /Bo
Old 26th December 2010, 09:20 PM   #10
You did not realize you were building sonic artillery?
Tang Band W6-1916 Abelma Full Range 2 29th July 2011 05:42 PM
Just finished desktop OB Tang Band W5-1611 mayhem13 Full Range 4 2nd December 2010 06:37 PM
Tang Band W6-789S 2 way. castlesteve Multi-Way 23 20th July 2010 10:06 AM
Tang Band W5-1611 Question Dxvideo Full Range 5 15th March 2010 08:35 PM
Tang Band W6-1139SI dshambala Swap Meet 7 10th March 2009 03:08 AM
Page generated in 0.09734 seconds (79.25% PHP - 20.75% MySQL) with 11 queries
