Sorry noob question. I got a pair of fe206esr, would the fe208E Sigma enclosure work with this driver? I have been searching but could not find anything about these in the 208E Sigma enclosure. Thanks
Tony |
#2 |
Please help, someone must know about this combo. I have searched the forum and cant find the answer.
Tony |
#3 |
i did. i bought a pair when they first came out.
mine are 12.5wx20"dx48"h. i added a 5" fountek ribbon cd2 tw. on the front baffel at the top. to me they sound great no need for a sub but i do have one. will try to get my son to post photos. whit all the wood they get very heavy. they are single layer. audioray--boston |
#4 | |
Do the fe206esr need the ribbon tweeters? I am planning on keeping the ones I have to try out. What cap value are you using with the tweeter? Tony |
#5 |
my ears are 69 years old. i had only .56uf to my ribbons. after conversation
with josh at madisound i started adding caps and ended up at 5.0uf. it depens on your ears i used a clarity red.do you need a tw. its up to you. my set up sound excelent to my ears. the fe206esr are a jewel. |
#6 | |
See if you can get your son to post those picture of the enclosures with the fe206esr in them, I'd like to see them. Thanks Tony |
#7 |
Hello,
donīt you find my HP? take view of my SAXOPHON and the RDH20, they would be a solution for the Fe206esr, because of the depth may be with an extra baffle of 25 mm. audioray, do you test your ears? imho you donīt need any tweeter, fostex has enough HT specially in your age, make measurements, 5ĩF seems to much if you dont cancle the Fostex at ~3kHz
http://www.hm-moreart.de |
#8 | |
Hi, thanks for sharing the pictures, very interesting designs. I will try out the super tweeter with the fe206esr, if I feel they are not needed then I will remove them, I agree with the cap value being high. |
#9 |
i did say i am 69 years old. i use to have a single gen.use to sweep 17'000 cyl.
i know the UF is high but to my hearing is fine. my fe168----fe167 do not have twt.no the206es-r do not need a twt. email your address i will send photo. audioray@hotmail.com |
#10 |
sorry,
in your case i think your hear the undertone one oktave below ~8-10 kHz because you must have more than ~110 dB 1W 1m there. IMHO
| Attenuation circuit findings Fe208e sigma | adamt | Full Range | 0 | 22nd June 2010 02:20 AM |
| Metronome FE208e Sigma | theskintman | Full Range | 3 | 2nd March 2010 06:21 AM |
| contour/notch filter for Fe208e sigma? | adamt | Full Range | 1 | 16th April 2009 02:15 PM |
| FE208E Sigma as midrange driver | LageB | Multi-Way | 3 | 8th January 2004 09:51 AM |
| Page generated in 0.10872 seconds (80.25% PHP - 19.75% MySQL) with 11 queries |
