Just in case anyone's interested, breaking these in before testing on a simple OB panel at my desktop. Have then crossed to a sub under my desk at 100hz and they sound pretty not bad. Highs are right there and crystal clear. Mids and midbass a bit weak which leads me to believe these are best suited to a ported box or some kind of TL. I'll reserve my final alignment once they've been measured. Very well made driver by the way. Construction is first rate with no noticable flaws. Magnet housing loaded with heat sinks so i imagine these can get pretty loud provided the mfgrs efficiency rating of 90db is accurate.
#2 |
How did you decide to go with and design your OB? Pics would be pretty not bad as well.
#3 | |
Regards /Bo |
#4 |
>>> The plan is to put them in 2 metre tall BIBs.
I hope it works out. Please post your results! I think this will turn out very well actually! Zilla |
#5 |
Just put them into some scrap 3/4" MDF panels with simple bases for now to break em in and get a feel for the tonality. They're already out now and off to be measured. if the results are good, they'll be posted. But they do sound very detailed. My final design will be a ported box of 14-18L tuned to 50hz.....or a mid for a three way possible 1st order if the top end is clean enough.
| S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range | gainphile | Multi-Way | 17 | 21st May 2012 12:17 PM |
| Tang Band W5-1880 | briandk | Full Range | 15 | 22nd November 2010 08:47 PM |
| Tang Band W5-1611 Question | Dxvideo | Full Range | 5 | 15th March 2010 08:35 PM |
| Tang Band W5-704D | revelator | Full Range | 0 | 1st February 2008 06:26 AM |
| Tang Band w5-704s | MITMechE | Multi-Way | 8 | 26th February 2007 02:38 PM |
| Page generated in 0.08369 seconds (74.36% PHP - 25.64% MySQL) with 11 queries |
