Old 1st December 2010, 12:43 PM   #1
mashypie's Avatar
Default Which would sound better?
A driver in a 1/4 wavelength tube or the same driver in its equivalent 1/2 wavelength tube?
Assuming size isn't an issue
Or would there not be much of a difference? I'm guessing that efficiency would be lower in the 1/2 length one...
Old 1st December 2010, 12:52 PM   #2
mashypie's Avatar
Maybe thats a bit of a subjective opinion...
Ok maybe I'm more interested in how they would differ in sound from each other, assuming they would at all
Wold one have more high freq attenuation than the other, would one be more efficient than the other, would one extend lower than the other? etc
Old 2nd December 2010, 02:47 AM   #3
brucegseidner's Avatar
I think we had better get an operation or some kind of emergent triage to separate your lady friend avatar from the loudspeaker. With that kind of diffraction grading potential I don't know how one would tell the difference.
Old 2nd December 2010, 03:48 AM   #4
frugal-phile(tm)
planet10's Avatar
1/4 wl pipe will be open at one end, and has the potential to get some bass augmentation,
1/2 wl pipe is closed at both ends, and will essentially have the extention of a sealed box.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd December 2010, 03:55 AM   #5
picowallspeaker's Avatar
So ,how do bass-bins (scoop) work ?
Old 2nd December 2010, 04:47 AM   #6
frugal-phile(tm)
planet10's Avatar
They are horns.
dave
Old 2nd December 2010, 08:59 AM   #7
mashypie's Avatar
dave
What if it were open though? ie like an extended TL
I've two drivers that I'm going to try this out with, just wondered if there was any input as to whether it would make that much of a difference
My initial feelings are that it wont, but then something tells me that while the 1/4 may be more efficient, the 1/2 will have more midbass attenuation
I've also got a little theory about some of the original TLs but I dont know if they had a different sound to more recent ones or not...
Old 2nd December 2010, 09:11 AM   #8
frugal-phile(tm)
planet10's Avatar
If it is open at one end it is a 1/4 w.l resonator. If its length is a 1/2 w/l of the Fs then it is tuned far too low.
dave
Old 2nd December 2010, 09:24 AM   #9
mashypie's Avatar
Shes actually a special tweeter lens that improves imaging and soundstage, to remove her would be detrimental to the sound, I'm sorry
dave
So you're saying there is no real advantage to tuning to 1/2 wl?
I will prob still try my project either way. But I'm thinking some original TLs were tuned in a 1/2wl (or equivalent) enclosure rather than the thought of 1/4 length.
Old 2nd December 2010, 09:35 AM   #10
frugal-phile(tm)
planet10's Avatar
Any tuning below Fs decreases bass output.
Not that i recall ever seeing.
dave
PC sound card sound chips kaluchka Chip Amps 6 20th June 2011 03:48 PM
The Ultimate Sound Improving for Compact Disc's through Patent-Pend.CD Sound Improver tiefbassuebertr Digital Source 145 25th April 2011 07:39 PM
comparing hi fi sound to car sound biamp Everything Else 12 27th June 2010 06:59 PM
SE sound vs Ultra Linear sound flysig Tubes / Valves 1 9th May 2009 10:21 PM
Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns opc Swap Meet 6 1st May 2009 03:48 AM
Page generated in 0.12474 seconds (80.54% PHP - 19.46% MySQL) with 11 queries
