Old 29th November 2010, 10:17 PM   #1
JimOfOakCreek's Avatar
Default Tang Bang W8-1772 Project Advice Needed
I am about to begin a Tang Bang W8-1772 FR speaker project.
Based on information from Bob Brines on this full range speaker I decided on a 1.5 Cu Ft BR cabinet with a single 3" port 4" long.
I have two questions.
1. Should a recess be routed in the cabinet for these speakers?
2. Does lining the inside of the cabinet with sound damping material make sense? The cabinet will be made with 3/4" Aspen. I know it may not be the ideal material but it's all I have available.
(I've got some DIY experience. I built a 2-way BR with a Seas 27TDFC/RS-180 designed by Jay Kim. Those turned out to be excellent sounding speakers when driven with my PS Audio Digital Amp & DAC)
Now, I want to get into FR speakers with a SET tube amp.
Thanks for any advice.
HiFi - Jazz - Wine
Old 29th November 2010, 11:15 PM   #2
tomchr is offline tomchr  United States
tomchr's Avatar
Unless you fancy diffraction, I suggest that you mount the drivers so the front of the flange is flush with the front of the baffle.
For the damping material, I suggest looking at Acousta-Stuf. At least give the flat surfaces a good coat of that to dampen box resonances.
~Tom
Old 29th November 2010, 11:46 PM   #3
Godzilla's Avatar
Enjoy building your project. I am curious if you will be using a circuit on the full range driver or not.
I would imagine TB was looking at the Fostex market with their 1772 and 1808 full range drivers designing a low and mid Qts for back horns and/or ported designs only to have Fostex revamp their line to primarily low Qts drivers.
I have the 1808 and it's great! If the similar looking 1772 is similar sounding then it too should be great.
Zilla
Old 30th November 2010, 12:29 AM   #4
Zilla
I hope not! But I won't know until I hear it first. The reason I want to try an SET tube amp and a FR speaker system is to get down to the very very simplist level as possible.
Initially I wanted to build an econowave for a SET tube amp. But I changed my mind after thinking about it a while. I don't want an X-over between the amp and the speaker driver.
What do you think about recessing the speaker? What do you think about lining the enclosure with sound damping material?
HiFi - Jazz - Wine
Old 30th November 2010, 05:12 AM   #5
That should read Tang Band W8-1772, not Tang *Bang* W8-1772. Sorry for the typo.
HiFi - Jazz - Wine
Old 30th November 2010, 03:22 PM   #6
mondogenerator's Avatar
Default cabinet damping.
i would line the internal walls of your box, as another poster pointed out.
if you can find it i would lone with 1/4-1/2" wool felt, or wool felt underlay (accounting for the volume taken up by the liner) and BAF wadding(acoustastuff, pillow fill polyfibre) on top of that. the BAF doesnt require much if any compensation for volume, unless you fill the entire box.
i. myself had been considering this driver too, although a 'simple' filter to tame the HF a bit, maybe just a single coil, or if necessary a gentle notch.
hope this is of some help, i have been loking at the TB fullrangers for a while now (and dribbling profusely)
good luck
Im starting to think its gone beyond a hobby, a wardrobe full of drivers instead of clothes...
Old 30th November 2010, 05:32 PM   #7
Godzilla's Avatar
They are dribble worthy!
Old 30th November 2010, 05:38 PM   #8
activexp's Avatar
Send a message via ICQ to activexp Send a message via AIM to activexp Send a message via MSN to activexp Send a message via Yahoo to activexp
Easy to do! Tand Band, Tang Bang.....I can never get it right first time
Old 30th November 2010, 06:16 PM   #9
Godzilla's Avatar
I've never recessed a driver before so can't comment on the sonic advantages. I'd imagine any advantage would be small.
I would stuff the cabinet loosely with acousta stuff... it's good stuff.
I have the 1808 not the 1772. I bought the 1808 in case i wanted to use it in a simple sealed box. I am sure Bob's box will sound good but i know he's not opposed to shelving down the top octaves of the speakers he designs with a clever circuit.
Old 30th November 2010, 08:03 PM   #10
frugal-phile(tm)
planet10's Avatar
Unless so dense as to not be worthwhile using wool or cotton felt does not take away from the internal volume... it will subtly increase the apparent box volume as would other damping materials.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Tang Bang W8-1772 Impressions. Bob Brines Full Range 411 28th March 2012 01:38 AM
FS: Tang Band W8-1772 Full Range Drivers bikinpunk Swap Meet 3 15th November 2010 09:52 AM
Pair Tang Band W8-1772 New $220 Michael Rothacher Swap Meet 3 25th May 2010 01:39 PM
FS: Tang Band W8-1772 full range drivers. xecluded Swap Meet 1 21st April 2010 11:03 PM
FS: Tang Band W8-1772 wideband drivers audiokinesis Swap Meet 2 21st February 2010 10:34 PM
Page generated in 0.12035 seconds (79.98% PHP - 20.02% MySQL) with 11 queries
