Old 27th November 2010, 03:04 PM   #1
Default Choosing the right weapons
Pardon me if this is posted in the wrong forum, but I'm looking for a holistic solution to my sonic woes. Oh... and I'm (arbitrarily) starting with a pair of stock FE167E's. <- negotiable, I'm not wed to them.
I've read everything I can find on wringing out every last drop of sonic goodness from these little workhorses. And results seem encouraging.
But... I believe in playing to the strengths inherent in our equipment.
And... I don't mind delaying gratification to get what I want.
And... I've got some latitude regarding system configuration and spatial constraints.
So... I could build a pair of 1/2 Chili's to try and get the little drivers to tow the load solo.
Or... I could build a cabinet that plays up the 100 - 5K strengths of this driver, build a high quality pair of subs, and couple the FE's with super tweeters (or whatever you kids are calling them these days).
Or... some combination that trades off crossover "tone robbery" for lack of physical coverage.
And, finally, this brings me to the corollary question which I will frame as a statement (hint: it's really a question): I've heard reports from more than one source, often accompanied by claims of being supported by math and physics, that speakers in sealed enclosures are "tighter" and "more musical" than their ported cousins, assuming the drivers in question are suitable to both.
IMPORTANT NOTE: I am *not* trying to incite a flame war. I'm simply trying to get a handle on the complexities of this acoustical engineering that some of you seem to digest with such great aplomb.
Now on the the ancillary information...
MUSIC: Musical tastes range from Baroque to Beastie Boys. I have a soft spot for strings and female vocals. Sound stage is high on my list of priorities. I will confess to liking the bottom 2 octaves quite a bit, but if they lack clarity (tightness) then I'd prefer they just didn't exist. I want my mid-range to have punch and presence. And I don't want my highs to be too shrill. I'm demanding of my system. I expect AC/DC and Segovia to both sound "present" and "alive." I'm not being morbid; I'm trying to describe the music.
AMPS: I've built Pete Millett's "Engineer's Amplifier," a push-pull 18W pentode amp and it sounds wonderful to me. I'm in the process of building a pair of Bruce's 20 watt push-pull KT88 monoboock amps. Lastly, I've got my sights set on Ti Kan's very fine Beta24 (170W @ 8 ohms). After all, a guy's got to have a reference amp against which to judge his tube equipment... right???
PRE: I'm close to finishing Bruce's ForeWatt and am in the middle of Ti Kan's Beta22 (fully balanced) for use with the Beta24.
SOURCE: I'm building Ti Kan's Gamma1 and Gamma2 in the hopes of turning it into a DIY high end CD audio source. In the meantime, I'm playing from a (pedestrian) Denon DVD-1600 or (god forbid) my iPod with compressed mp3 source. Lastly, I've got an old Pioneer with a fair-to-midland Shure M97xE cartridge which runs through the so-so Oatley RIAA tube phono stage.
*** Any help at all is greatly appreciated. ***
Old 29th November 2010, 08:51 PM   #2
Godzilla's Avatar
Build all three and see which sounds best to you. There are lots of designs to choose from for the 167e. It's a good choice for a full range driver of it's size. I would build a BIB personally and leave it on its own using one of the tube amps you are building. There are several good back horns for it too. Or you can try the OB route tho i am not sure who here has. You can also seal them up and add a sub and probably get very good results.
Old 29th November 2010, 09:09 PM   #3
chrisb is offline chrisb  Canada
This enclosure works quite well with FE167E, and the topology has proven to be compliant with a range of driver brands and sizes.
It's the same enclosure you inquired about in another thread, and the photo posted there is interior of one of the pair below. The required volume is such that they could be built without the lower void cavity, but then stands would be required , and this way you could include a small woofer per side for a killer active system.
Sealed / ported / horns / TL, etc? I'd say it's more a matter of implementation and system synergy than of simple theory that "I read somewhere (on the internet)"
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Last edited by chrisb; 29th November 2010 at 09:20 PM. Reason: correct contextual reference
Old 29th November 2010, 11:51 PM   #4
Godzilla's Avatar
Those look really well proportioned Chris. Amazing how many options are available now for full range fans! Honestly, the speakers pictured look like something you own and enjoy for many, many years. Beautiful.
Zilla
Old 30th November 2010, 01:35 AM   #5
Brisso57's Avatar
Default A "left-field" suggestion to use your 167's
Look at Quarter-wave.com
MJK has a plan to use a FE167 on OB with 2 x Eminence 15A Alpha's.
... as I said, perhaps this is not for you.
cheers
Doug
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all."
Old 30th November 2010, 01:46 AM   #6
vinylkid58's Avatar
I'm going with the "classic" Fonken style cab for my drivers. Unless I change my mind of course.
jeff
Old 30th November 2010, 02:37 AM   #7
frugal-phile(tm)
planet10's Avatar
Jeff, can you render that image in perspective... is that an FE167 model or just good pencil work?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th November 2010, 02:52 AM   #8
vinylkid58's Avatar
Not an exact FE167 model, but the frame size should be close.
Ok, here's a perspective shot:
jeff
Are tectonic weapons feasible ? Borat The Lounge 43 6th November 2010 06:06 AM
choosing an enclosure ed2000145 Full Range 0 11th May 2009 12:57 AM
Help choosing capacitor value? sbelyo Tubes / Valves 15 28th April 2006 08:29 PM
help on choosing insulator rebojorge Pass Labs 4 4th March 2005 07:26 AM
spl weapons Chris8sirhC The Lounge 9 13th March 2004 03:21 PM
Page generated in 0.10805 seconds (79.34% PHP - 20.66% MySQL) with 11 queries
