Old 24th November 2010, 01:19 AM   #1
Default What to do with this driver?
Hi everyone, how you all doing? This is my first post in this forum.
I have recently acquire a pair of this......(see attachment!)
It is an 8 inch Beckman full range with only the following information from the vendor:
BECKMAN
Model Beckman 8" 5 Stars
Type : Bass reflex ( Full range for disco )
Power : 50W RMS
Impedance : 8 ohms
Résonance : 45Hz
Freq : 35Hz - 15KHz
Magnet weight : 20 OZ
Coil : 1-1/2”
1- Does anyone in here have any info's about its T/S parameter?
2- What can I do with this pair of drivers?
3- What type of enclosure would you suggest ? ML - TL - HL or whatever ?
I am thinking of making a pair of omnidirect ful range for music listen only, my favourite are Jazz, vocal, instrument, orchastra-classical.
Please help and thanks in advance !!!
Old 24th November 2010, 02:34 AM   #2
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default What to do...
Welcome Sagamotto.........
We are all assuming the T/S parameters are going to be rather hard to find...& myself I can't seem to locate any info also. Do you have any test gear that you can rig up to get the T/S numbers?? Like AF generator, multi-meters, components, etc??
Myself....when I see these big (8" plus) full-rangers.....I'm tempted to build an ultra-simple open baffle. Especially when the T/S is nowhere to be found...and I just want to listen, I get a big sheet of MDF, cut a hole in it ....listen while I decide how I'm going to approach it. Often times I like the OB so much I wind up "jazzing up" the crude OB & let it go at that.
A 4x8 foot sheet of 3/4" MDF pre-cut at the store...I'd go 30" by 48" with the remaining cut-offs for a "footing/stand" assy. A centered hole about 2/3s' the way up.
_______________________________________________Ric k.............
Old 25th November 2010, 02:32 AM   #3
Thanks for the reply !
I have recently been doing a bit of experimenting with different BR enclosure and ran accross this and it is totally blew my mind...
Here is the link:
MCAP-CR_Suggested_Cabinets
Wonder if the Beckman would work in the TR225a2 enclosure ?
Does anyone here also has any experiences with such propose unique BR design ?
Thanks !
Old 25th November 2010, 04:30 AM   #4
The driver looks to have a decent sized magnet so should be capable of some good stuff - however, you won't know (including which cabinets are suitable) until you get it's parameters: To measure drivers: Download ARTA: ARTA ARTA Download, Make this simple jig: ARTA Jig - http://zobsky.blogspot.com/2008/01/s...t-jig-for.html ]
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
L-pad attenuator for midrange driver 6 1/4 inch driver rhythmdiy Multi-Way 0 4th November 2007 03:32 PM
Base driver to suit ESS Heil driver gerado Planars & Exotics 6 1st August 2007 07:56 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
Driver/ driver configuration improve soundstage width andy2 Multi-Way 6 16th June 2005 08:47 PM
mtm versus tm driver recommendations on project with $500 driver and xo part limit gsattler Multi-Way 4 20th May 2002 05:54 PM
Page generated in 0.09273 seconds (76.52% PHP - 23.48% MySQL) with 11 queries
