Old 23rd November 2010, 07:59 PM   #1
Sergii is offline Sergii  Ukraine
Default Sonido drivers (data)
Hi to all,
herewith I post some technical data for Sonido drivers for guys, who looking for:
Some explanations:
A - for alnico, No A - ferrit, SFR -SuperFullRange for BLH, SWR - SuperWideRange for BR.
There are also SCW-midwoofers from dia 200, 300, 400 mm.
I already built 2 enclosures BR with SWR145A (12 Liter-box) and SWR200A (52 Liter box).
Now is building of BLH on driver SFR175-8 in progress.
Old 23rd November 2010, 08:30 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 23rd November 2010, 10:05 PM   #3
Hi Sergii,
Really interesting!
Can you provide some detail on how you took the measurements? For example, I assume the drivers are mounted in the cabs, and the measurement took place indoors? If so, could you say more about the room dimensions, the speaker's proximity to the walls etc.?
Thank you in advance!
Old 24th November 2010, 06:27 AM   #4
Originally Posted by rjbond3rd View Post
Hi Sergii,
Really interesting!
Hi, rjbond3rd,
all graphics I`ve got from the manufacturer Ishvan Varga (Sonido).
all measurements were done for dia:
145 in closed encl. 10 liter
175 -//- 16 liter
200 -//- 22 liter
on axis from distance 1 m.
Room dimensions - 30 m2 (5 x 6 m), relevant for LF till 300 Hz
Additional to my first post: the second FR is for SWR200A
Below photo of drivers SFR175 + SCW300. Some guys have built quasi 2-way speaker in BR-enclosure. Full range + LF-section (lower 150-200 Hz).
Old 26th November 2010, 07:59 AM   #5
hm is offline hm  Europe
hm's Avatar
Default sergii
Hello,
my KORNETT, POSAUNE is built with the 145 + Sph135 Monacor,
exellent feedback, goog..Translate helps.
kornett FB in the middle
in this case a 160 mm width inside
posauplan
for the 175 the Posaune
for the 200 Posaune with 280 mm width inside
and a bass, size up to 150% to the front driver
invers with +- change.
with feedback, measurements
http://www.hm-moreart.de
Old 26th November 2010, 04:51 PM   #6
I just wanted to share some information about Sonido drivers from my comp I collected the last year. So if there is a need of somebody I can attach also some shematics of enclosures simulated and made by Ishtvan Varga without any costs etc.
Here are also data for the smallest driver SFR145-8 and 145A. Enclosure BLH which very easy to build. The most detailed and emotional sound of all Sonido drivers. I have the similar one for Bass reflex SWR145A. For rooms till 20 m2.
Old 28th November 2010, 06:26 PM   #7
BDP is offline BDP  United States
Default Zen Mod
From another thread you were working on enclosures for the SFR-200 driver. Do you have some pictures you can post?
BDP
Old 28th November 2010, 06:35 PM   #8
Zen Mod's Avatar
they're in box made by Sonido plans
pictures are here http://www.diyaudio.rs/topic/2138-so...post__p__43060
it's pair made by my friend Igor (SuperFi)
there are some plans to make another one lsp with SWR200 AlNiCo on OB and either 12" or 15" Sonido in ML TQWT
we'll see when ......
Old 28th November 2010, 06:46 PM   #9
BDP
Another one for SFR200 is called "Sand watch"
Old 28th November 2010, 07:30 PM   #10
pictures are here Sonido Proto Ayon - diyaudio.rs
Why the SWR200A is your better choice for OB with 12" or 15"?
I think the SFR200A would be better because the lighter membran with the nearly same motor - as a result more resolution and more sensivity - 95 dB or 93.
Interesting BLH From Sonido Of Hungary thetubeguy1954 Full Range 34 15th April 2012 06:57 AM
Sonido BIB peterbrorsson Full Range 68 23rd January 2011 09:31 AM
new Sonido SWR200A-8 Zen Mod Full Range 67 26th November 2009 06:24 AM
need data on gauss hf drivers! Flo666 Multi-Way 1 30th November 2005 09:45 PM
Page generated in 0.11321 seconds (77.99% PHP - 22.01% MySQL) with 11 queries
