Full range Open Baffle with Current Drive - Page 4 - diyAudio
Old 20th February 2011, 08:29 PM   #31
I have TB-W8-1808 in 24 inch wide OB without any kind of filter.
My amp is a factory (kitchen) buildt F4.
The low end is taken care of with a pair of Klipsch RSW-10d subwoofers.
It sounds fantastic. But after reading the article about fullrange&current source i was curious.
Mr Pass. Do you reccomend a particulary filter here?
Hans Erik
Old 20th February 2011, 08:42 PM   #32
knutn is offline knutn  Norway
A picture could be nice...
Old 20th February 2011, 10:18 PM   #33
The one and only
Nelson Pass's Avatar
I have not played with it enough to recommend a specific
for the F4 or similar. Most likely you will want to consider
taking some of the edge off the upper mid with a small
coil in parallel with a resistor, this in series with the driver.
Old 21st February 2011, 08:54 AM   #34
Uploaded with ImageShack.us
Old 21st February 2011, 08:55 AM   #35
Old 21st February 2011, 03:33 PM   #36
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by el`Ol View Post
Currently I am working on BLOB (backloaded OB). Conical baffle, opening towards the rear, and placed in front of a room corner. Is in a very early stage however.
Wow, I had some thoughts along these lines last summer, a speaker that looks like a jet engine - any drawings etc ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 15th February 2013, 09:51 AM   #37
sraudio is offline sraudio  Lithuania
sraudio's Avatar
Have you tried active equalization instead of simple L/R circuits? What kind of speakers do you use, and how would you describe the difference between current drive and voltage drive?
Don't think about filter circuits, go active equalization. Because you have to correct the response not only at the lowest frequencies. I have a lack of time to post more things on Home, but there is some comparison between OB fullrange current drive system vs Proac response 2.5 clones. Sound difference is big. I don't listen the Proac clones if OB system is in that room.
Old 15th February 2013, 03:08 PM   #38
guangui is offline guangui  Puerto Rico
White board with white driver looks very nice.
Looking for Full Range for mid in Open Baffle dcathro Full Range 32 12th May 2015 08:50 AM
Full Range and the Semi-Open Baffle Capt Zach Full Range 26 29th June 2010 05:13 AM
Edge ? full range open baffle pforeman Full Range 3 12th June 2010 12:47 PM
Building full range open baffle? Glowbug Full Range 27 22nd January 2007 11:15 PM
full range (open baffle) then_dude Full Range 15 9th March 2004 03:58 PM
Copyright 1999-2017 diyAudio
