Madisound BK-20 - Page 2 - diyAudio
Old 6th November 2010, 09:53 PM   #11
frugal-phile(tm)
planet10's Avatar
BSC lowers sensitivity. MF/HF are reduced sto bring them in-line with the bass that is being put out. In your small room you will probably only lose on the order of 3dB max. An 8 w SET should still drive you out of the room if you crank it.
Something like Sachiko has bass gain, so that the lowest frequencies are brought up to the level of the mids so you loose nothing.
More of concern with a SET is the affect of the impedance on the amplifier. That said, Jim uses a SS amp with low output impedance, your SET will have much higher output impedance which will naturally boost the bass. That along with significant room gain (ie small room) may mean that you can actually get away with little to no filtering.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th November 2010, 10:58 PM   #12
debk is offline debk  United States
debk's Avatar
Thanks for the information. I think the best way to go at this time would be to build the HC's. With the SET amp I will try it first without the BSC filter, it will be simple to add it later.
If I want or when I move the system to a bigger room, I can always take the drivers out and put them in a Sachiko cabinet.
Again thanks everyone for your input.
Deb
Old 7th November 2010, 01:45 PM   #13
debk's Avatar
I remeasured my room. It is about 14 X 17. Seating is along the long wall. From the couch the speakers will be about 11ft away.
While still maybe not ideal for the Sachiko's my gut tells me to go with the Sachiko's.
Deb
Old 7th November 2010, 11:20 PM   #14
frugal-phile(tm)
planet10's Avatar
That is quite a bit bigger than we thot before. And listening just far enuff away. Pushed close to back well and out from side walls should work fine.
dave
Old 27th February 2011, 05:05 PM   #15
debk's Avatar
I wanted to build the Sachiko's, but the workspace I would use to build them is unheated, and not usable till later in the year. So, to have something now I built a pair of the Madisound BK-20's, with Fostex 206eN^2 drivers ( still want to build a pair of Sachiko's later in the year as time permits). I am diving them with a 300b SET amp. They have 100+ hours on them.
The bass is quite adequate, and the mids are incredible. When listening to solo piano music it sounds like a the piano is in the room.
The issue I find is that voices tend to be a little shrill especially when listening to them straight on.
Would a BSC or Zobel help with the shrillness? Any ideas would be appreciated
Debra
Old 27th February 2011, 06:05 PM   #16
frugal-phile(tm)
planet10's Avatar
Pictures Debra?
You can try the 98 cent whizzer trick.
You can also play with toe-in. Try it such that the axis of the drivers cross a bit in frnt of you.
A Zobel's effect will depend on your amplifier. Given that the copper cover on the pole piece of the 206, it is unlikely to have much effect.
BSC shelves down everything aove a certain frequency, in essence lifting the levels of the bass.
I'd let them get another couple hundred hours on them before firming up any filters.
dave
Old 27th February 2011, 06:19 PM   #17
Originally Posted by debk View Post
The issue I find is that voices tend to be a little shrill especially when listening to them straight on... Would a BSC or Zobel help with the shrillness? Any ideas would be appreciated
Hi Debra, the usual remedy is to make sure you're listening at least 15 degrees off-axis. If you check out the Fostex PDF for this driver, you'll see a diagram which shows the frequency response (a) straight on (i.e., zero degrees off-axis), then 15, 30, 45, 60 or something like that.
You want to pick the degrees off-axis where the driver starts to flatten out. Too much off-axis and you lose the highs (of course).
If you still feel the treble is rough, or too beamy, in addition to being X degrees off-axis, you might want to experiment with a rear-firing tweeter which can add some air and sparkle.
Any tweeter you get would have to be fairly efficient, e.g. Fostex F17H which are about $40 each (if I recall correctly).
If you still aren't satisified, the next step is to roll off the 206 with a single inductor, and then roll in the tweeter (by changing the value of the cap) letting the tweeter do more and more work. I know you can get a much smoother treble this way, and it will be less beamy (more dispersion) which many feel is pleasing.
None of this is really -necessary-, but it's just taking the next step to perfection if you feel like it.
Old 27th February 2011, 07:24 PM   #18
Jim Shearer's Avatar
My experience w/ FE206e is limited to building a pair of Half Changs using the 206. BSC is a real hot botton issue, but I have used it to good effect on the HCs, FE108eSigma Metronomes, and FE127e Fonken Primes.
With the HCs I used 1 mH air core inductor and 5 ohm Mills resistor. Without the BSC they were rather 'shouty' and fatiguing.
I didn't finalize the BSC until I had 500+ hrs on the drivers. If you only have 100 hrs, then you can still expect some significant changes.
Almost forgot to mention: your choice of amp will significantly affect your decision on BSC. I use 1970's vintage SS receivers. If you are into tubes, then things could be very different.
Cheers, Jim
A day without music is like a day without food.
Old 27th February 2011, 09:38 PM   #19
debk's Avatar
Purple Heart Veneer with a shellac finish. Turned out ok, finishing is not my forte.
Old 27th February 2011, 10:01 PM   #20
debk's Avatar
A combination of the 98 cent trick and toeing them in helped a lot.
Deb
Madisound Fostex BK-16 cabinents whitelabrat Swap Meet 2 12th September 2015 09:25 PM
Madisound Bk-16 Kit review JeffG Multi-Way 23 14th November 2013 01:28 AM
Fostex BK-20 as bass for H420 wood horn? Doug Kim Multi-Way 2 2nd April 2013 03:18 AM
Tang Band 1808 in Madisound BK-20 cab? Racket Scientist Full Range 1 25th February 2012 07:45 PM
Power Amp Toroids 20-0-20 VAC 500 VA daedalus Swap Meet 17 24th May 2006 08:30 PM
Copyright 1999-2017 diyAudio
