I want to try one last experiment before I fork out 900 dollars for the F200a. If this experiment doesn't work, I can always return the B20 drivers to parts-express.
Price for 8 drivers is only 160 dollars plus the cost for tweeters. I figure I can't lose! Is it possible to do a BIB with four drivers per side? What enclosure will work in the corners with this many drivers? Am I nuts for trying this in a 10 by 12 foot room? It seems like it has never been done. I figure at 19 dollars a driver, we should come up with something crazy. Give me some ideas! |
#2 |
frugal-phile(tm)
Ii will be BIG. There might be room for you in the room after you get the speakers in -- might require you to remove a wall to get the forklift thru...
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
I would try it with a 19 Ohm driver ,not a 19 $ driver...
#4 |
I plan on using OSB board so it won't cost as much compared to birch plywood. Are there any plans along these lines?
#5 |
No worries about comb filtering? Folks have tried to buy multiple drivers per side from me, I always discourage them. But I haven't tried it myself.
Paul Wild Burro Audio Labs - DIY Full Range Speakers |
#6 |
Would a quad chang work in this situation?
#7 |
Go for an OB with 5 Pioneer / side.
One in the center FR and 4 surrounding it LP'd as a conjugate helper woofer. |
#8 |
Ok gimme 10
#9 |
How would I get the bass output I need with 5 drivers on each side in an OB. Has anyone ever done an BIB with two drivers on the side magnet to magnet and two in the front?
#10 |
Sorry but I would focus on whatever but bass .Have you considered drivers' offsets ? How are you gonna tame with four different directivity patterns and +100 different kind of reflections ? Ok ,they sit in a corner
| Best Enclosure for Pioneer B20 | tripathdude | Full Range | 23 | 2nd July 2010 12:07 PM |
| A Pioneer B20 Enclosure... | shloky | Full Range | 6 | 13th September 2007 12:06 PM |
| Pio B20s . . . finally and again | Kensai | Full Range | 2 | 11th January 2007 04:09 AM |
| pioneer subwoofer enclosure | grujo | Subwoofers | 1 | 5th July 2005 11:40 AM |
| pioneer sub 4 home use. what enclosure?? | felzi | Subwoofers | 18 | 13th June 2005 06:08 PM |
| Page generated in 0.09743 seconds (78.44% PHP - 21.56% MySQL) with 10 queries |
