Old 3rd November 2010, 02:58 AM   #1
Default Voigt Pipe Fullrange with Radiator
This is a hybrid design I created with small (desktop) size in mind. Its a partially stuffed folded pipe with driver 1/3rd from tapered end. I added a passive radiator in place of a vent to hold in the sulphur hexafluoride gas. Sound in this gas is slowed down to 44% of its speed in normal air. It is 6 times denser than air.
Fountek FR135EX 5" Full Range
https://www.madisound.com/store/prod...oducts_id=8817
Peerless 5.25" Mini Passive Radiator
https://www.madisound.com/store/prod...oducts_id=1748
Now to build and test.
Quoting Bentoronto from this Instantly deepen your sub?
"The heavy gas, SH6, works in a few different ways.
Tucked behind the driver, it adds to the room in the box.
Tucked into the horn, it makes for a big horn. Similar but nutty variations of front-face gas loading are possible as in the patent pictures.
The third way is by magnifying the cone surface area. Instead of shaking a heavy chuck of cardboard to move air directly, you are using that cone (with force transfered by the heavy gas) to shake a far larger membrane surface.
These gas-filled boxes breathe a bit. About once a year or two, I have to set my speakers so that the gas falls to the bottom and the valve (a Schrader tire valve!) is at the top. After settling a few hours, I add or relieve some air.
I'm no authority to trust, but I think SH6 is pretty inert and innocuous. It can still leak out, like any gas. The danger is that it is an invisible gas that collects in low spots and might get in the way of normal human breathing - and be dangerous.
Given the dramatic lowering of bass resonance(s), sure seems like a good idea for DIYers to try. No leading-edge technology needed. But what do I know?"
Old 3rd November 2010, 07:22 AM   #2
CLS is offline CLS  Taiwan
To avoid all kinds of troubles related to gas leak, how about freezing the air inside?
By dropping the temperature, air gets denser. Talk about fridge-like speaker! LOL
Old 3rd November 2010, 07:26 AM   #3
chris661's Avatar
In that case, wouldn't it be better to have more than one of these passive radiators, or maybe even go to an 8" one?
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 3rd November 2010, 03:13 PM   #4
Shouldn't be much leakage with the interior coated and sealing putty under the driver rims.
More concerned with the internal volume, but a pair of side radiators would be interesting.
"Tucked behind the driver, it adds to the room in the box."
Old 3rd November 2010, 04:52 PM   #5
frugal-phile(tm)
planet10's Avatar
When Dayton-Wright did this the gas was in a plastic bag.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd November 2010, 11:51 PM   #6
Two rads on split face.
Old 4th November 2010, 12:12 AM   #7
Hi, I'd walk before you can run and take on board very dubious claims, rgds, sreten.
undefinition
Zaph|Audio
FRD Consortium tools guide
RJB Audio Projects
Speaker Design Works
HTGuide Forum - A Guide to HTguide.com Completed Speaker Designs.
Humble Homemade Hifi
Click below to go to
Quarter Wavelength Loudspeaker Design
The Frugal-Horns Site -- High Performance, Low Cost DIY Horn Designs
Linkwitz Lab - Loudspeaker Design
Music and Design
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
voigt pipe new design? zycomatique Full Range 4 20th July 2010 06:00 PM
Voigt pipe as a TQWT Keriwena Multi-Way 5 21st June 2010 10:17 AM
Voigt Pipe is looking for new home mkapszewicz Full Range 9 21st December 2009 02:17 PM
Folded Voigt Pipe Ropie Full Range 18 2nd November 2005 03:31 PM
MTM on a Voigt Pipe ? johninCR Full Range 2 8th April 2005 06:20 AM
Page generated in 0.10247 seconds (77.62% PHP - 22.38% MySQL) with 11 queries
